Monitor 40 Series II Online measurement and review
Hansvelton
Hansvelton Posts: 151
https://www.audiosciencereview.com/forum/index.php?threads/polk-monitor-40-series-ii-review-speaker.24146/
Just found this. Wow they really trashed them. A few stood up for these.
Are they really that bad??
  • ken brydson
    ken brydson Posts: 8,652
    They're a sub $200 pair of speakers. Amazon and Crutchfield reviews are 4.5 or better. I've never seen a front baffle fall off . I'm guessing shipping damage. I recently got S20's. A bit more expensive at $300 (list) a pair and the fit, finish, build quality and most importantly SOUND is way above the price point.
    VR3 Posts: 28,070
    I've never heard the speakers in question, but those guys stored listening to music years ago, in sure for their price point they do great
    F1nut Posts: 49,830
    VR3 wrote: »
    I've never heard the speakers in question, but those guys stopped listening to music years ago, in sure for their price point they do great
    Fixed it for you :)
  • ken brydson
    edited June 2021
    VR3 wrote: »
    Fixed it for you :)
    Remember when Sid was too young to drink ?🍷
    VR3 Posts: 28,070
    Aye autocorrect, gracias senor Jesse
  • Hansvelton
    Yeah never heard the current monitor line, a bit too entry level to me, but never heard of Polk making anything truly "bad".
  • MikeUp
    MikeUp Posts: 86
    That website has been said to have inaccurate test procedures and rarely do they go by the actual sound quality. I wouldn't even entertain the idea that anything on their website is true or accurate.
    I read reviews from reputable magazines and even some online listener reviews which I found to match the way I hear them for myself, and found good reviews for the Monitor and TSI lines which are similar but not the same.
    The cheapaudioman did a review of my Polk TSI100 and loved them putting them above many speakers costing more including Polks other, more expensive series. See here.
    Here's a review of the TSI200 which was the model that succeeded the Monitor 40 Series II. See here.
    Also another review of my TSI100. See here.
    I thought about buying the TSI200 ($130 more than my TSI100. Almost 2X the cost) or the Monitor 40 Series II ($50 more than my TSI100) but why, I have an excellent subwoofer and the TSI100 goes low enough in the bass to be good.
    The TSI200 didn't really add much bass or efficiency, and for my setup, offered no benefit for the extra money. A step up to the TSI500 would be my only option, as for my needs, had the only benefit worth the extra money. Even then, it would only be heard when using direct mode, bypassing my subwoofer.
    On to new and better adventures
  • Gardenstater
    Gardenstater Posts: 4,195
    I didn't see much glue in that basic rabbet joint and not much or too little press out on those corner braces. If they had built the thing with a rabbet and dado joint it never would've happened. I don't excuse it as shipping damage. Bad construction.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    VR3 Posts: 28,070
    Honestly, I've seen alot of Polks from that era with that construction and you can rip the baffles off with your hand. I've seen numerous ones from the rtixx series, ie rti12
  • JustM1ke
    JustM1ke Posts: 6
    TSI and Monitor series ain't that bad of series. I used to own a pair of TSI300s, got them for $110 together from a pawn shop. Top had damage like most used TSI's out there. They were pretty good, too bad I didn't really use them that much. On the used market, I see the TSI200's and TSI300's almost priced the same.
