Hex Screw Removal
jumpindick
in Electronics
So I was trying to get the top of the preamp off. It had a few hexagon head screws on it. One of the screws was stripped to start with. How do I remove it? I have tried the rubber band trick, latex glove and few other, but so far no success. Any suggestions?
If it is stripped socket but the screw isn't tight anymore, I'd super glue an alan key into it and remove it that way. If it is stripped and tight good luck! I'd say you could try the same or JBL Weld epoxy or the like, but I wouldn't hold out much hope. I usually have to grind a slot in them for a slotted screwdriver blade but that will definitely mess up the surrounding cabinet sheet metal.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Gardenstater wrote: »If it is stripped socket but the screw isn't tight anymore, I'd super glue an alan key into it and remove it that way. If it is stripped and tight good luck! I'd say you could try the same or JBL Weld epoxy or the like, but I wouldn't hold out much hope. I usually have to grind a slot in them for a slotted screwdriver blade but that will definitely mess up the surrounding cabinet sheet metal.
Yes the socket and stripped with the screw tight too. I just ordered micro screw extractor to see if that would help. It's gonna be a pain in the neck to get it out for sure. -
If the screw extractor doesn't work, tape the area off really well, and drill the head off. You might be able to extract the remaining screw down the bottom.
Be careful with the extractor so as not to snap it inside the screw head.
Also, if you have a large soldering gun or even just a soldering iron, try applying some heat to the screw head with some of Gardenstater's tips as long as there's no direct contact with plastic.I disabled signatures. -
Blowtorch...
If it is metric try and find a standard size that you could lightly tap in and see if that would grip enough to loosen. Also maybe try a torx bit that could be tapped in and see if it would grab enough. Not sure how sensitive the electronics are so?2 Channel
Pre: Bryston BR20
Amp: Buckeye NCx500
Speakers: Polk L200
Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
Display: Sony XBR65Z9F
Pre: Anthem AVM90
Amps: Buckeye NC502
Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
Subwoofers: SVS SB16 x 4
Source: Oppo UDP-205, Apple TV, Amazon Fire
Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
Display: Sony XBR85Z9G -
Drill it out.Political Correctness'.........defined
President of Club Polk -
Drill it out.
+1 to that. Use a drill bit with 90 degree tip. Maybe even try one with a 60 degree tip, used mostly for plastics. That way you remove more from center than edges compared to a 118 or 135 degree tip. You are less likely to mess up the countersink in the cover that way.
An EDM disintegrator machine might be bad for the electronics...Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
If you do decide to drill it out use a left hand twist bit. If you're lucky it may save using an easy out and the possibility of breaking that off.
LOL Beat me to it! After sleeping on it I was going to say to try a slightly oversized torx bit and tap it in. One could even make the splines sharper with a dremel fine cutoff wheel. Wouldn't hurt to tap it in with some JB Weld and let that cure a couple days. Then see what's what.
PS: If you happen to have some liquid nitrogen (it could happen) try freezing the torx bit first to shrink it lol.Post edited by Gardenstater onGeorge / NJ
iFi nano iDSD DAC
iPurifier3
Thank you all for the ideas. This weekend will be fun as I go through it.. Idea about drilling makes most sense, but equally terrifying.
Maybe step it up to hammer drill. For good measure.I disabled signatures.
jumpindick wrote: »Thank you all for the ideas. This weekend will be fun as I go through it.. Idea about drilling makes most sense, but equally terrifying.
Well, if it were me I'd try the press fit oversized torx bit with a little epoxy first. You can always drill later if need be. Can't do it the other way around. Just sayin'.George / NJ
iFi nano iDSD DAC
iPurifier3
Carnage report?
Did it escalate from measured approach with precision tools to bench vise, animal fat, and hedge trimmers?I disabled signatures. -
Also what kind of preamp is it?
Carnage report?
Lol... I really wanted to use miter saw with 12" blade, a compound miter saw in particular. I got this awesome idea that I should slide the blade, while it is spinning, to create one deep notch on the screw head, and then use a flat head screwdriver to take it out
. But then, fudge it... I don't want to damage my saw either. May be I have cursed hands that whatever I touch gets bad or damaged..... In all seriousness though, the preamp has gone back to the dealer who is going to take care of it. The issue is that the front display panel would be lit some times displaying the info, and not lit the other times. Function wise, the preamp is jut fine and works without any issues. We needed to run the firmware again to take care of it. So had to ship it out to the dealer. -
Lol
Ah, probably best. I probably wouldn't have had the patience for that until I removed all other screws and bent and twisted the cover off. And the screw would remain. Without a scratch on it.I disabled signatures. -
Lol
That's what I would do, too (FWIW). And I would use a bevy, nay, a fusillade of socially acceptable words whilst doing it, and probably for most of the remainder of that day.
(it pays to keep a list of expletives handy for times like those)
Assuming this is already resolved but personally I would have used a dremel tool with a small abrasive disc to cut a notch in the top and remove with a flat head screw driver. Or maybe an angle grinder with a thin cut off wheel if you have balls of steel and steady hands. Taping the top off first is a given of course. I fabricate a lot at work and drilling out machined threads is my last resort.Rega Planar 8, Apheta 3 MC , Aria mk2 Phono
Aurender n100h, Benchmark DAC2 HGC
Arcam SR250, Parasound JC5
Revel F208, SVS SB-4000 -
Needle nose vise grips. Although I have also used the method above with success.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
