Cleaning glasstop electric stove
So, want to clean the touchpad on the stove but how do i clean it well w/o activating any of the settings and such? Sorry for what is probably an easy to answer question but couldnt find the answer web wise and dont want to screw anything up...
thanks!
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
  • monepolk
    monepolk Posts: 1,154
    Don't have one, but I would switch the circuit breaker off.
  • Emlyn
    Emlyn Posts: 4,719
    Shutting off the circuit breaker to the stove seems the easiest way to me, followed by unplugging it from the wall outlet. I've never done either. Unplugging from the wall may involve pulling the stove out and damaging flooring underneath if the plug's not easy to get to. A slightly damp cloth with a little soapy water in it should be all that's needed to lightly clean the touchpad. Some appliances also have a screen lock function but not all of them do. Here's an example from LG:
    https://www.youtube.com/watch?v=9PJwSrarJ3o
  • GlennDog
    GlennDog Posts: 3,152
    What helps me, is dampening a paper towel and laying it upon the surface. Let is set a few min, depending how dirty it is. This way the debris cleans up better/removed easier . . . ymmv
    409 work well, too
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • starkiller
    starkiller Posts: 2,723
    Got it figured out, thanks everyone!
  • skrol
    skrol Posts: 3,452
    edited May 2021
    Stan
    Main 2ch:
    HT:
    Other stuff:
    tonyb Posts: 33,072
    If your just cleaning the glass over the electronics, just spray some decent window cleaner on a paper towel first then wipe. Most any ceramic top cleaners work just as good as the next with a little light scrubbing pad. Try not to use the heavy duty scrub pads as they may scratch the top.
    One thing I've noticed with many brands of ovens...and electronics, is that they seem to want to place the oven vent right under the electronics panel. Nothing good can come of that design and your electronics is in more danger from that than cleaning the panel with a liquid cleaner. Just my .02
  • steveinaz
    steveinaz Posts: 19,545
    Mr. Clean pads are perfect for induction-top stoves. Then Ceramabrite.
    audioluvr Posts: 5,920
    tonyb wrote: »
    and your electronics is in more danger ....
    Okay so SF/ mafia intel aside... Treat it like you are just about to meet the Italian woman of your dreams parents and your not sure yet if that's a good thing or your life is epically in danger. And then realize you need to stop posting drunk. JMHO!
