No more 3.5 mm jack on iPhone 😞
kevhed72
in Electronics
My old iphone had one and it was quite nice to just hook it up to a receiver with a 3.5 mm to RCA cable and boom.... Tune In or whatever was available for streaming. I have a Marantz pm5004 and a pair of RT25i I want to move into my new office but this won't work w iPhone12. Whats a work around or a decent Bluetooth speaker idea, as most of these seem jenky to me. Thoughts...?
There exists a lightning to RCA adapter cable, but it looks like it'll be doing the DAC work, and not sure you'll be getting much there for $15.
https://www.amazon.com/Splitter-Adapter-Compatible-Lighting-Amplifiers/dp/B087NBNWXP
Off the top of my head for another wired option, I'd say try a Schiit Modi with USB, or something similarly affordable < $100.
Or Audioengine's B1 or similar, though I prefer Schiit's DACs over Audioengine's.
Might also consider a Raspberry Pi option and forgoing the iPhone for all but controlling the RPi?
I used to use the IOGEAR Tunetap BT receivers before I got a few Squeezeboxes, and they sounded pretty good, but they don't make them anymore. Plus, I was using the optical out and the pre or processor was handling the DAC duties. I think you'll probably want something better inline for a DAC, though, than that which these lower cost devices might provide.
Maybe check into Topping stuff, too. I know Drew liked at least one of their products.
Are you going to hook up a sub with those RT25is? I used to run a set in the home office. Pleasing, but needed a sub.
What about using an old dedicated computer or other repurposed mobile device instead of your phone?I disabled signatures. -
If wifi is available just use an older cell phone it doesn't need to be activated to use wifi and you could also use a cheap DAC like a Blu- dDentoGustard X26 Pro DAC
This would be for the office, so wifi may be completely out of the question due 'security concerns'. I guess I assumed cell phones have DACs inside them? I also didn't know a lightning connector is used for an audio signal as well as power. Boy, maybe I am a boomer!
https://www.amazon.com/Certified-Lightning-Headphone-Compatible-Supported/dp/B07DNRF36G/ref=mp_s_a_1_11?dchild=1&keywords=lightning+to+mini+jack&qid=1619981485&sprefix=lighting+to+min&sr=8-11
Lots of cheaper options on Amazon as well.
Or this with a lighting to USB adapter for significantly better sq: https://www.amazon.com/AudioQuest-Dragonfly-V1-5-DragonTail-Extender/dp/B00OLYQPAK/ref=mp_s_a_1_1_sspa?dchild=1&keywords=audioquest+dragonfly&qid=1619981608&sprefix=audioquest+&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzQ1UwUUNOTkdBVVg5JmVuY3J5cHRlZElkPUEwNDM3MjgzM0E1V1g1WUVaUEczVyZlbmNyeXB0ZWRBZElkPUEwNzI4MDUyMUU1WVpHTEhGNVNYUiZ3aWRnZXROYW1lPXNwX3Bob25lX3NlYXJjaF9hdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVlLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Ohhhh, your work office. I thought you meant at home. Yeah, a sub probably won't be welcome.I disabled signatures.
Lol, trust us to make things complicated.I disabled signatures.
Quit looking this is the best one out there
https://www.amazon.com/Mangotek-Lightning-Headphone-Certified-Headphones/dp/B08634JBYT/ref=sr_1_18?dchild=1&keywords=iphone+plug+to+3.5mm&qid=1619989448&sr=8-18"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
tophatjohnny wrote: »Quit looking this is the best one out there
This may be the ticket cost wise, although the AQ Dragonfly is intriguing. Thanks much gents!
