Monitor 11T Volume Issue?
alecd70
alecd70 Posts: 13
So I've had these older speakers for over a month now. It seems that ever since I have used them (as fronts) I need to turn up the volume higher on my receiver. I have not upgraded anything on the speakers and all of my other speakers are 8 ohms (does that even matter?). Would the tweeter upgrade "help"? Would using contact cleaner on the binding posts "help"? Thanks in advance for any help!
    pitdogg2 Posts: 27,245
    edited May 2021
    Do your midwoofers above and below tweeter move in and out freely? Apply even pressure with fingers and thumb around the dust cap and push in and let move back out. Can you feel scratching or does it move freely? Froze not wanting to move? Do not force it.
  • alecd70
    alecd70 Posts: 13
    Thank you for the response. All of the woofers (and passive radiators) move freely. Does the tweeter appear ok?
    msg Posts: 10,459
    The tweeter's definitely the problem. There's a small man living inside it!
    I've noticed a volume differential between speakers before. Is this an AVR or stereo receiver?
    F1nut Posts: 51,956
    Any time you change anything in an HT set up you must run the AVR calibration program again.
  • alecd70
    alecd70 Posts: 13
    Good one, msg! Haha. It's an AVR I am running. And F1nut I have yet to run Audssey on my Denon receiver ever since I hooked these up.
    F1nut Posts: 51,956
    That was obvious.
