Cheap Sony SACD player
gwh
gwh Posts: 1,451
edited February 2005 in Electronics
Thought about picking up one of these, got a $30 gift card from BB. Currently don’t own a sacd player and have been playing reg. cd’s through my cheap Mitsubishi dvd player since my very old Denon cd changer bit the dust.
Current gear:
Denon 3803
Adcom five chan.
LSI’s all around
Does anyone own one of these?
Any thoughts or advice would be appreciated on this player.
I know it’s on the cheap side of the spectrum, but I would really like to check out sacd and I like the multi disc setup.
G
Link
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Post edited by gwh on
  • stereo55
    stereo55 Posts: 418
    I have a Sony DVP-NS775V single disk player with the same basic specs as the one you posted , and so far have no complaints about the Sony with sound or picture .
    I did find the same player your looking at over at Amazon with a few reviews HERE
    SDA-2B's ~ Pair SDA-CRS's ~ ,*** Main listening: Maggies MG1 ~ Polk SDA 2B's ~ Monitor 10's , 3-pairs (2 pairs moded into SDA's w/SDA-2B/CRS cross-overs) , * DCM TF600's * Mission M71/M72 *** Main brdrm FRT: RTiA-5's /Presence RTi-4 / LSI-704 Cntr / Rear FXI3's ~~~ Assorted Main listening rm : , 2- Heathkit W-5M /tube mono blocks (Parasound P/HP-850)* * 2- Altec Lansing 1590b's/mono blocks (Yamaha C-45) * CM Labs 35D * Dynaco ST-70 ~ Occasionally ~* Yamaha CR-820/A-760 ,* Sansui AU-317/AU-217 * Carver 900 rec *2-Dynaco ST 120* 1 Hafler DH-220* Marantz 1040 ... more
  • Danny Tse
    Danny Tse Posts: 5,206
  • gwh
    gwh Posts: 1,451
    Alright, thanks for the info.
    I think I’ll give one a try since I can’t find a Denon sacd changer. Does Denon make one?
    Anybody Know?
    G
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
    F1nut Posts: 51,998
    From what I've read/heard about the inexpensive Sony SACD machines is that the SACD playback is pretty good with the CD playback not so good, but inline with what you get from any CDP in the same price range.
  • Danny Tse
    Actually, the CD playback quality of the Sony 595 is surprisingly good. I think you will have to go either the Sony C2000ES (the ES version of the 595) or a dedicated CD player in the $250.00 - $300.00 range to better it.
  • gwh
    gwh Posts: 1,451
    Well I’ve done an about face and picked up a used, supposedly mint, Denon DVD 2200
    for $260 shipped off AG.
    Guess I’ll have to get off my lazy butt to change disc.
    G
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
