Unknown Polk Bookshelf Speaker
kjsnfl
kjsnfl Posts: 15
I found a great deal on a used set of bookshelf speakers, but the stickers were missing. I did a shootout with my Rti4's, Monitor 40's, and Tsx220b speakers and preferred the new speakers. They have 5 1/4 woofers 1 inch tweeters with dynamic balance on them, 2 small front ports, and the rear power port. Anyone know what model I have? I'm also wondering it there is a tower from this series.
  • kjsnfl
    kjsnfl Posts: 15
    Mdaudioguy, thanks for responding. That is what I thought at first. The rt15i has blue woofers. The ones I picked up have black woofers.
    I'm really interested to figure this out because these speakers sound really good compared to my other Polk speakers.
  • kjsnfl
    kjsnfl Posts: 15
    edited April 2021
    This auction says they are rt15i as well. But the stickers are missing on them like mine. 😆
    VR3 Posts: 28,100
    I believe there was a standard rt15 as well
  • mdaudioguy
    mdaudioguy Posts: 5,165
    Yes, Polk often introduced a model, say RT15, and then a few years later, would come out with an improved version RT15i. Maybe blue woofers are better! ;)
  • skrol
    skrol Posts: 3,340
    Blue woofer are always better. Much better than yellow anyway.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • kjsnfl
    kjsnfl Posts: 15
    Thanks guys! That's it, Rt15.
    Now I'm curious if the rt15i is brighter than the Rt15. Seems like a tactic used to "update"Maybe a speaker model. the rt35 with 6.5 inch woofers would be nice as well.
    For a 10 dollar thrift shop speaker, I was blown away. I like the balanced sound better than the rti4 which has been my go to for a while. The rt15i has better/tighter bass compared to the tsx220b as well.
    msg Posts: 9,493
    I'm not sure about with the Rt15i because it does not seem to have the tri-laminate tweeter which people really seem to enjoy on the larger RTxxi speakers.
    From
    https://forum.polkaudio.com/discussion/comment/2326466/#Comment_2326466
    rooftop59 wrote:
    The black silk dome tweeters are fine, fairly detailed and not too bright, but don't have as much as or extension as the tri-lam dome tweets.
  • kjsnfl
    kjsnfl Posts: 15
    Msg, thanks for the link.
    I have never heard the tri lam tweeter which appear to be silver . I think I want to try them out at some point. How do they compare to Polk's silk dome tweeters?
    All the reviews I've read say they don't seem too bright or fatiguing.
    I have experienced terrible ear fatigue with Energy aluminum tweeters. That's what always brings me back to Polk silk dome tweeters. I have never had an issue with Polk's.
  • gp4jesus
    gp4jesus Posts: 1,969
    edited May 2021
    I’m confident that front baffle helps the SQ
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
