RC55i tweeter
PLOKA
PLOKA Posts: 1
I have just purchased the RC55i's as my rear speakers. I am installing them in the ceilling. Which direction do I install the tweeter. Toward the front wall, back wall, inward, or out? The directions discuss adjusting the tweeter with your fingers, but not which direction to install them.
Thanks.
Post edited by PLOKA on
  • mantis
    mantis Posts: 17,380
    edited February 2005
    What I do when I install inceing speaker is I point the tweeter away from the listening area if used as rears and towards if used as fronts or center. Wen Installed the inceiling , you have to play with the direction of the tweeter and se if you Install it it will point the way you want. If it doesn't spin the speaker untill it's in correcty. There is no one way to do it.
    Also don't install the inceiling overhead. Keep them out to the sides or back of the listening seating area.
    Dan
    Dan
