Twisted Pear Dac - almost done
Been messing with this for well over a year. A "friend" @SCompRacer built one, loaned me some parts and off I went.
Twisted Pair ESS Sabre Pro ES9028 chipset and the Mercury Analog board make up the heart. One t'former and PS saved up for either a USB card or Toslink Optical. I attempted the Amanaro but had absolutely no luck getting it to synch up. I did get a Sonore to synch but it didn't sound right. So I'm using the Schiit Eitr USB to S/PDIF converter and feeding it from Roon.
The cabinet is from a Yamaha CA1000 receiver and the plate from a Sansui AU999. I like to use stuff I've got laying around. The black back is 1/4 plastic from the backing of my Salamander rack that I've never used but is heavy enough to support everything. I just have to figure out how to attach it now. I understand the blue paint tape is a nice touch but... :# I've got a piece of red oak that I have yet to finish for the front. Might pull that blue LED (indicates lock) into the front.
It's been "fun". Not much support from Twisted Pear anymore so if something doesn't work out you just hope to find an old article.
Got the C4 hooked up to with with Senn HD800s's. Very very nice!!
Aaron
Enabler Extraordinaire
    pitdogg2 Posts: 27,257
    Nice work as usual Mr. Rock-a- Feller....
  • agfrost
    agfrost Posts: 2,474
    Very cool, Aaron. Rich didn't sweet-talk a 2nd enclosure out of the Italians when he built his TP dac back in 2012, eh? Dommage.
    Jay
  • ALL212
    ALL212 Posts: 1,664
    agfrost wrote: »
    No, but I do have that Dac also! But if I start chopping that up I’ll lose the fancy schmancy display Rich spent 1/2 his life getting to work. Got plans for that one...
    Aaron
  • mantis
    mantis Posts: 17,557
    Pretty damn cool.
    Dan
  • invalid
    invalid Posts: 1,521
    I think the lampizator guy gave the older buffalo dac a tube output stage. He said it was the best sounding dac at that time.
    heiney9 Posts: 25,496
    Very nice (as usual) Aaron.
  • ALL212
    ALL212 Posts: 1,664
    Front attached - color is close enough. Not sure yet what to do with the back. Trying a piano hinge but I’m not happy with it.
    Aaron
    SCompRacer Posts: 9,121
    edited April 2021
    ALL212 wrote: »
    Found this zip tie hinge thing...... :#
    edited April 2021
    agfrost wrote: »
    Aaron got the 9028, I went Twisted Pear ES9038 version and kept the second Italian chassis.
    The 9028/9038 have choice of eight output filters. The Mercury output board balanced out has no common mode DC between ground and balanced pos or neg. The 9038 analog output section is duplicated 4 times and connected in parallel. Just a bit better playback.
    Rich went plain Jane with his second Italian case. USB in, balanced out. R and L channel get their own 15v PS. I didn't want to give up any more lifetimes to get the Arduino and display to work. Maybe when I retire....
  • ALL212
    ALL212 Posts: 1,664
    Found I really liked the sound on the headphone rig so I threw it in the main rig for a bit. Liked that also.
    So the Schiit Yggy is parked. The Schiit Yggy might go up for sale!
    Darn cabinet is HUGE but I got it crammed in the shelf sideways. Can't see it anyway...it's a DAC so no controls.
    Aaron
  • ALL212
    ALL212 Posts: 1,664
    Decided to follow @SCompRacer and put an ES9038 together. Could not get it to play right and worked with Brian over at TP. He finally realized that what I had was a left channel only mono chip in it. Got the right chip in it today and now... it does blow the ES9028 away.
    Dual power supplies for the Mercury analog board. This is Rich's 9018 chassis and everything fits.
    Aaron
    ALL212 wrote: »
    You should rent that extra space. :D
    Yeah, that extra dough for the 9038 is worth it. Nice work. I thought about mono settings but man, a whole chip? :o
    edited July 2021
    This is what it once looked like in there. Dual mono, Arduino with remote control, faceplate design software for CNC, HiFi 2000 face plate milling and anodizing, Arduino programming, every DAC input known to man, SACD input from modded 3910, 37,506 views at TP forum, lol. I learned soooooo much from that DAC.
