need front speakers
hello! i'm trying to replace my front speakers with rti12 or rti8. my current set up is onkyo tx-ds898 with 110 watts/channel rms, csi40 as center, fx50 surrounds and svs sub. 70%ht and 30%music. pls advice.
Post edited by licer on
Honestly, split the difference. Go with the RTi10's. The 8's IMO just don't compare (definitely lack in areas) but the 12's are a little overkill if you're just off a receiver. I sell more 10's than 12's and 8's combined.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
your next step will be to go with a CSi5.
Get the 8's or pick up a pair of RTi70's if you can find them. The 10's and 12's really need a separate amp to sound their best. The rest of your setup is fine.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
