need front speakers
licer
licer Posts: 9
edited February 2005 in Speakers
hello! i'm trying to replace my front speakers with rti12 or rti8. my current set up is onkyo tx-ds898 with 110 watts/channel rms, csi40 as center, fx50 surrounds and svs sub. 70%ht and 30%music. pls advice.
Post edited by licer on
  • Toxis
    Toxis Posts: 5,116
    Honestly, split the difference. Go with the RTi10's. The 8's IMO just don't compare (definitely lack in areas) but the 12's are a little overkill if you're just off a receiver. I sell more 10's than 12's and 8's combined.
  • eaadams
    eaadams Posts: 213
    your next step will be to go with a CSi5.
  • Early B.
    Early B. Posts: 7,900
    Get the 8's or pick up a pair of RTi70's if you can find them. The 10's and 12's really need a separate amp to sound their best. The rest of your setup is fine.
    "God grooves with tubes."
