New Thread: Diffraction Pads/Rings
She did give me a look earlier.. You know that death look that wives have down pat when the sonar is pinged... That one- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Yeah
When you come home she’s standing there with that look on her face not saying anything. Just waiting to see what lie you’re about to tell so she can catch you in it and hold it over your head until the day you die!
Hey Beevis
These are COOL😎 -
Stoopid kwestion
Where do you get those Velcro dots you guys were talking about?? -
honestaquarian wrote: »Stoopid kwestion
Velcro dot elves..... -
Hardware store, Lowe’s, Amazon, etc."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Office depot and the like will also.
Im using the ones that come with the picture mounts since the adhesive leaves no residue- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Are these the right ones?
Really any velcro should work- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Do you have pricing for SRS2's? I know a guy who would want some.Polk SDA SRS 2A
Aragon 8008X3
Aragon Soundstage
Multiple Digital Sources -
Yessir
Looks to be the same as the 1c! Already have it drawn up. I'll send you a Pm- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Good deal! Looking forward to these.Polk SDA SRS 2A
Aragon 8008X3
Aragon Soundstage
Trey, would like a set for some 2.3TL's, check your p.m.
Hey Mike! Got it!
Will send invoice today
Thank you!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Received the diffraction pads in a very timely manner. Thank you!! And they're the advanced oval design. Cool.Polk SDA SRS 2A
Aragon 8008X3
Aragon Soundstage
