Karma: Pre-cut SDA 2 Dynamat Kit
spongebobsquarepants
Just did Dynamat on my SDA-2A drivers, and had some left over. I figured I’d cut an extra set with the scrap, and see if anyone wants it. Enough pieces for SDA-2A or SDA-2B.
First person to post a picture of the speakers they’ll use it on can have the kit.
Very nice of you.
President of Club Polk -
Would they fit a set of CRS as well?
Nice Karma.Don't take experimental gene therapies from known eugenicists. -
You might need some trimming for the PR, but the drivers should be the same!
Surely someone will take these off your hands.Don't take experimental gene therapies from known eugenicists.
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
@vmaxer
Cool! I loved the change this made to the sound of my speakers, hopefully you will too!
Please PM me a shipping address
