Anyone Need parts from a PSW1000?
rtart
I've got a PSW1000 (black and rosewood panels) that has a bad amp. I wound up with it a few years ago, and the previous owner had replaced the amp. He did a 'what I have laying around' job with it, so the amp isn't up to to the task. I did some research and it looks like the 'best' replacement option was an amp that runs over $400 now. The last thing I need is another sub, so I don't need it even if the amp was less $$$.
Before I pitch it or donate it, thought I'd see if anyone needs drivers or other parts. Cosmetically it is decent, and would blend really well with other Polk gear, like the Lsi series.
If you need something let me know. I'm in the ATL area.
My 7.4.4 DIY 4k Home Theater:
Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
Polk LSiM 702s x 4 on the Ceiling Atmos speakers
Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
Denon X3700H Emotiva XPA11 Gen 3
XBox One X 4k & BD and streaming
Panasonic UB-420 4k player
HD-A35 HD DVD
Oppo BD-103D for hirez audio
Technics SL-D2 TT, Grado Gold Cartridge
JVC DLA-RS2100/NZ7 projector
Silver Ticket 135" microperf AT screen
Berkline 090 electric recliners with Aura Bass Shakers
HD-A35 HD DVD
odd question, but would it work if you connected it to the speaker in from an external amp?
As you may recall, the PSW1000 amps were prone to failures. A cottage industry of what to do with them sprung up, and one idea was to replace the plate amp with a blank plate and add speaker terminals to use an outboard amp. So, yes, it would work. An amp designed for sub use would be the best option, since an adjustable high pass filter would be included. If not, a separate EQ device would be needed. Still $400....My 7.4.4 DIY 4k Home Theater:
HD-A35 HD DVD
Berkline 090 electric recliners with Aura Bass Shakers -
Didn't know any of this. I already have a PSW650 that will receive a signal when initially turned on but then goes into standby mode. Also a RT1000 that emits an enormous buzz when I attempt to play anything through it. I have enough to do's or I'd take it. -
I’m looking for a psw1000 but hoping to find a working unit.
Just curious where you’re located since shipping these is $$$.
Do you have the original broken amp still or no? -
Looks like AtlantaPio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
HD-A35 HD DVD
Sorry. Totally missed that. Do you still have the original broken amp by chance?
Nope. The amp is from some other sub. The guy that had it apparently just bolted on what he had laying around.My 7.4.4 DIY 4k Home Theater:
HD-A35 HD DVD
burialcloud wrote: »Sorry. Totally missed that. Do you still have the original broken amp by chance?
By chance, I have one in my PSW1000. Amp is dead but has never left the sub box.
