TV headphones
acmf74
in Headphones
Hi Polks..
I'm looking for a new pair of wireless headphones to connect to my TV. I'm not looking for something fancy just to watch some movies late at night. Any recommendations for around $150
Only caveat is that my TV only has an optical audio out and not the tradition L/R RCA plugs.
TIA
TIA
Unfortunately it doesn’t have BT either. Thanks though.
Thanks Rick. I picked up the Avantree model. 🤞
I have these.
https://www.radioshack.com/products/auvio-wireless-stereo-headphones.
Got them in 2014 for when I work outdoors. Used with ipod for tunes, garden is about 90'+/- away.
I just fired em up, still work fine with the tv & ipod.
Thank you. I should be getting the new headset tomorrow and should have a good idea on whether they are keepers or not.
I picked up the Advantree Ensemble and so far it’s been great. It came already paired and it sounds very good. It’s has zero background noise plus a long lasting battery. I highly recommend it for tv.
Go for Advantree
