Static from using the remote
daboyz
I've got a Rogue Audio Magnum 99. When the volume is turned all the way down and until you're at a decent listening level there's static coming from both speakers. Nothing crazy but noticeable. I can manually use the knob and it's dead quiet. I sprayed the pot out just for the giggles and nothing different.
It seriously doesn't bother me but just wondering....
So you're selling static??
It seems that I've got it in spades. 🙂
Also, if you know me I have a propensity to buy and sell a lot. I had a potential buyer and he's not liking it so I'm just trying to come up with something. -
I've seen a number of folks complain about volume control issues with Rogue gear. Have you reached out to Rogue?Political Correctness'.........defined
President of Club Polk -
Sounds like interference from the receiver circuitry of the remote control function is seeping into the signal path. I agree, see what Rogue has to say.
Sorry. Didn't mean to put it here in the fm. Yeah. I emailed Rogue last Friday. I haven't heard back from them.
Does the static stop when the voices speak to you?Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
SCompRacer wrote: »Does the static stop when the voices speak to you?
Oddly, no. Them sons of beeches just keep on yapping. 😥
I'm wondering why @ALL212 hasn't chimed in yet... -
If there are tubes in there just take ‘em out. If there are no tubes put some in.
Problem solved!Aaron
Enabler Extraordinaire -
Email Rogue, Mark or Nick typically respond very quickly, a couple hours.Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
Problem solved!
Godly advise I bow to you🙏 -
From your description, it sounds like the motor for the volume is creating electrical noise. This is not uncommon. Just to be clear, the noise is only when the volume is changing by the remote? Or is it noise at all positions until it is louder? You said it is quiet if you manually turn the knob.
If this was not always like that from the factory, it could be a bad capacitor or ground connection on the motor control circuit. However, some designs just have that noise when the motorized volume is changing. -
Agree with above, this shows up more in tube gear. When I built my first PC music server that was plugged into my DAC then too my tube preamp, I could here microphonics when I moved my wireless PC mouse when searching music.2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Just by using the remote. I emailed Rogue a week ago and haven't heard back. Kind of a bummer because when I had an issue with a 66 I had prior they were on top of it rather quickly. 😕
Problem solved!
I took the tubes out and stuck metal hangers in instead. Now the damn thing will only let me listen to country music. -
I have a Rogue 99 in my stockpile of preamps and mine has the same issue. I never asked Rogue about it though. In the Stereophile review measurements section, they do mention that the grounding is "suboptimal."
I've had more than a few preamps that use the ubiquitous Alps motorized volume pot and none of them has that issue. On the other hand, for the used price of a 99, it's not hard to overlook given the sonics when the volume control is not moving.KEF Xq5s / Velodyne DD12 / Apollon Purifi 1ET6525SA / SST Thoebe II / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
