Polk SDA 2 tweeter polarity.
I'm putting a pair of SDA 2 with the single center SL 2000 tweeter back together that have been sitting for a while. Short memory. Want to make sure I have the polarity correct. White is positive and black is negative, correct?
    pitdogg2 Posts: 27,047
    Black is positive
  • gary7
    gary7 Posts: 10
    Just want to be sure as the SDA uses out of phase for the SDA effect.
    edited January 2021
    gary7 wrote: »
    White* is always negative in polk with the exception of the RTA12 speakers
    * Monitor and SDA I've had experience with.
    F1nut Posts: 51,768
    gary7 wrote: »
    Black or blue = positive
    White or green = negative
  • gary7
    gary7 Posts: 10
    That's what I thought. wanted to be sure.
    Brandcraft reported
  • gary7
    gary7 Posts: 10
    edited February 2021
    Ok. Just got the replacement tweeter. Want to double check things. Mine are the SDA 2 with the single center tweeter. Now pics I have seen show the tweeters in a mirror image orientation, with the top of the tweet Polk Audio name facing toward the outer edge of the case. So regardless of which way the tweeters are oriented, the black is positive & the white is ground, correct. I don't know why I don't write these things down when I take things apart.
    F1nut Posts: 51,768
    Correct
