Cullen cable power strip
marvda1
For sale Cullen cable 4 outlet 15 amp power strip with 4ft avius se power cord. You won't see this on his site but look at the connector compared to the one on the regular avius cord.
$240 shipped PayPal friends and family.
https://www.cullencable.com/111-2/
Puritan PSM156
Puritan PSM156
Post edited by marvda1 on
Is the cable just the regular Avius cable and the SE signifies the different plug?2 Channel
Pre: Bryston BR20
Amp: Buckeye NCx500
Speakers: Polk L200
Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
Display: Sony XBR65Z9F
Pre: Anthem AVM90
Amps: Buckeye NC502
Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
Subwoofers: SVS SB16 x 4
Source: Oppo UDP-205, Apple TV, Amazon Fire
Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
Display: Sony XBR85Z9G -
i believe it is the plug, he says to him it sounds better than the gold series cable.
it is a sonarquest connector but not the one he uses on the crossover series 2 cable. the body of this on is metal.Post edited by marvda1 onAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
While the metal shell "may" keep away outside interference out, it in no way is any different as to how it connects to the conductor body as it and the nylon bodies attach the same way to the conductor body. I've used sonarquest I like that they have a long flat conductor part. More flat surface area to touch the blade of IEC socket. They also grip very well to the IEC blades.
Love them. -
$215 shippedAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
$169 shippedAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
$160 shippedAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Great deal here"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
Bump $160 shippedAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
$155 shippedAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Just asking a few questions hopefully to help out. Since it's not the same as the one in your link I think people may be a bit unclear on what they're getting: What AWG and purity is the cable wire? I assume it is stranded not solid? What is the plug made out of......4N red copper? Gold plated? Each outlet is 15 Amp, and the cord is 30 Amp? What materials are in the outlets........is it gold plated 4N copper? Thanks.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
it is his avius cables with upgraded sonarquest plus connectors.
12 awg x 3 (99.99% OFC Copper Conductors)
Super Flexible
110% coverage of spiral wrapped Aluminum Mylar Shielding with 20 awg tinned copper drain wire.
PVC – Polyvinyl Chloride dielectric
25 Amp Rated
14mm in diameter
Made in the USA!
i believe this is the connector he uses.
https://www.sonarquest.net/alloy-edition/red-copper/sonarquest-p25-r-t-aluminum-alloy-red-copper-series-audio-grade-ac-power-plug-connector.htmlAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I’ll take it Marv! Fool not to."if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
SOLD !Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Cool piece brother! Great pack and thanks for the quick ship! Got it in the mix !"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
thank youAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156
