Cullen cable power strip
marvda1
marvda1 Posts: 4,962
edited January 2021 in For Sale (FS) Classifieds
For sale Cullen cable 4 outlet 15 amp power strip with 4ft avius se power cord. You won't see this on his site but look at the connector compared to the one on the regular avius cord.
https://www.cullencable.com/111-2/
Puritan PSM156
Post edited by marvda1 on
  • sgmsmg
    sgmsmg Posts: 556
    Is the cable just the regular Avius cable and the SE signifies the different plug?
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
    Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Sony XBR65Z9F
    Pre: Anthem AVM90
    Amps: Buckeye NC502
    Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
    Subwoofers: SVS SB16 x 4
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
    Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
    Display: Sony XBR85Z9G
  • marvda1
    edited January 2021
    i believe it is the plug, he says to him it sounds better than the gold series cable.
    it is a sonarquest connector but not the one he uses on the crossover series 2 cable. the body of this on is metal.
    Puritan PSM156
    pitdogg2 Posts: 27,240
    While the metal shell "may" keep away outside interference out, it in no way is any different as to how it connects to the conductor body as it and the nylon bodies attach the same way to the conductor body. I've used sonarquest I like that they have a long flat conductor part. More flat surface area to touch the blade of IEC socket. They also grip very well to the IEC blades.
    Love them.
  • marvda1
    $215 shipped
    Puritan PSM156
  • marvda1
    $169 shipped
    Puritan PSM156
  • marvda1
    $160 shipped
    Puritan PSM156
  • Great deal here
  • marvda1
    Bump $160 shipped
    Puritan PSM156
  • marvda1
    $155 shipped
    Puritan PSM156
  • Gardenstater
    Gardenstater Posts: 4,802
    Just asking a few questions hopefully to help out. Since it's not the same as the one in your link I think people may be a bit unclear on what they're getting: What AWG and purity is the cable wire? I assume it is stranded not solid? What is the plug made out of......4N red copper? Gold plated? Each outlet is 15 Amp, and the cord is 30 Amp? What materials are in the outlets........is it gold plated 4N copper? Thanks.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • marvda1
    edited April 2021
    it is his avius cables with upgraded sonarquest plus connectors.
    12 awg x 3 (99.99% OFC Copper Conductors)
    Super Flexible
    110% coverage of spiral wrapped Aluminum Mylar Shielding with 20 awg tinned copper drain wire.
    PVC – Polyvinyl Chloride dielectric
    25 Amp Rated
    14mm in diameter
    Made in the USA!
    i believe this is the connector he uses.
    https://www.sonarquest.net/alloy-edition/red-copper/sonarquest-p25-r-t-aluminum-alloy-red-copper-series-audio-grade-ac-power-plug-connector.html
    Puritan PSM156
  • tophatjohnny
    tophatjohnny Posts: 4,189
    I’ll take it Marv! Fool not to.
  • marvda1
    SOLD !
    Puritan PSM156
  • tophatjohnny
    marvda1 wrote: »
    SOLD !
    Thanks Marv it will come in handy on the bedroom rig !
  • tophatjohnny
    Cool piece brother! Great pack and thanks for the quick ship! Got it in the mix !
  • marvda1
    thank you
    Puritan PSM156
