WTB: Dreadnought Case (or equivalent)
kickngas
I have parts on the way, but having a difficult time finding a suitable case like the one Larry used to sell. I am open to suggestions, or an original Larry's case if you are tired of looking at the one you bought with good intentions for building a Dreadnought...and never followed through!😉
what parts you got?
Avel Y236906 should be here Saturday. Researching/Deciding on cable and terminals as we speak.
reach out to @westmassguy he may have a case or could point you in a good direction.
Thanks for the advice!
Go on ebay and search "aluminum box" there's like a zillion of them.Gustard X26 Pro DAC
Yeah, but trying to get a specific size sort of limits the selection. I have found a Hammond recommended by a member here that will work just fine.
Yes I couldn't remember the name of the case I had for my 800. Hammond it was. I will say that they fit very tight in there and you really don't need to bolt it to the case because the case actually clamps it between the shells of the top and the rest of the box at least mine did I didn't even have enough room to put any dynamat in it
This one is the Hammond 1550NBK and it is about 10 x 10 x 4. Just realized I haven't ordered it yet
That's about correct. I never measured mine but it was smallish. -
Nope nope nope.... -
ken brydson wrote: »
Pffft that would require a scanning electron microscope.
Geez jump in with both feet you big sissy 😂😂 -
I think I have one of Larry's 1st gen cases in the stash, but it's set up for binding posts, not Neutrik.I disabled signatures.
I already ordered my case or I would have bought yours. I'll bet it would sell fast on the classifieds here. -
Yeah, no sweat. That spare one I have is pre-drilled for binding posts and most people switched over to Neutrik now for current Dread builds, so it's not the first choice anymore.I disabled signatures.
