LS50 bi-amp Upgrade
jakeo25
Hello, I am doing a bi-amp upgrade to my LS50 speakers, wondered if I should replace the existing crossover circuit. I was planning to drive the lower speaker as a woofer from the main amplifier, and drive the second 6.5" speaker (as a mid-range) with the tweeter with the second amplifier. Any thoughts on crossover frequencies for the LS50 cabinet?
Yamaha RX-V565
Polk LS50 modified with LS70 crossovers
Philips SBC-HP250
Philips SBC-HP250
For starters your speakers only have one set of binding posts. Proper bi-amping is a very deep hole, one that you don't want to go down.Political Correctness'.........defined
President of Club Polk -
What exterior xover do you have and what amps?Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
I will update my profile. Thx for reminderYamaha RX-V565
Philips SBC-HP250 -
So you swapped in crossovers from LS70's into your LS50's? Uhh, yeah, that's not the proper way to get bi-amp capabilities(Not to mention it's pointless on those speakers).
What would really seal the deal on this experiment is to tell use you are going to bi-amp using a receiver.
