Unable to connect Polk Magnifi Mini to Google Home
Hi all !
I'm a french customer of the Polk Magnifi Mini soundbard and I'm not able to connect it to Google Home app. What is the process ?
Here is my issue:
- I'm adding a new device to Google Home, it detects the soundbar.
- Then it connects to the soundbar, and just after, there is always the same message (when my phone switch from the local Wifi to the soundbar wifi):
Here is the screenshot: "A problem happened. The application cancelled the device selection demand".
What should I do to solve this ?
Many thanks.
Here is my issue:
Many thanks.
I suggest sending an email message to: [email protected] and explain the situation. He will be available next week.
Game Room HT: Denon AVR-X4200w; Sony UBP-x700; Definitive Technology SM450; Definitive Technology LCR2000; Definitive Technology StudioMonitor350; Mirage Nanasats; Sub - HSU VTF-2 MK5
Master Bedroom
Cambridge Azur 551r; Definitive Technology promonitor 800; ACI Titan Subwoofer
As a follow up for those with the same issue, I just fixed it and thought I'd share.
You'll need to be comfortable side loading APK files
1. Uninstall the current Home app you have installed
2. Download a much older version of the Home app from here: https://www.apkmirror.com/apk/google-inc/google-home/google-home-1-30-43-11-release/google-home-1-30-43-11-android-apk-download/download/
3. Install the newly downloaded APK from the link above. You may need to allow installation from sources other than the Play Store
4. Pair the speaker in this old version. This worked perfectly for me without any hitches. The process is slightly different because of the older UI but pretty self explanatory.
5. Update your Home app back to the latest version via the Play Store.
6. The speaker will remain paired and will work as expected!
Sorry dude, but when someone shows up and makes their first post as a hyperlink, 99/100 times it’s spam, and we get a LOT of it. Thanks for sharing the solution!
Master Bedroom
Not a problem - I just got my first Magnifi and spent about a week trying to get it connected to my wifi......
