Kwang Sung Electronic KSP-S095(1) DSW500 (150W) Power Supply for subwoofer
Albert007
Does anyone have a schematic for this component? The resistor (R4) near the STM VIPer 12A (U1) has totally fried. Thanks!
Resistors generally burn up when something else fails. Just a heads up that you'll likely need to determine what else failed or any replacement resistor (if you figure out the proper value) will also fail in short order.2 Channel - Polk SDA-2BTL, Carver TFM-35, Peachtree iDAC, Qobuz streamed via Episode Lynk using bubble UPnP server
