New Person Same Buzzing, Static, Heartbeat issue with my Polk Audio PSW125
Polk Audio Powered Sub - maybe 12 inch, cant find a model number, purchased from FutureShop and had a 9 year warranty but they went out of business and its has a consistent heartbeat ticking sound unless you turn it off, also it has static buzzing and will appear to come one and off. PSW125, I see that several other people have the same issue, what can I do to get this repaired??
  • The cause of the problem is a failed bass amplifier which would need to be repaired or replaced. I believe there are service facilities in Canada, send an email message to: kim.jasper@soundunited.com he should be able to send you contact information. It might take a day or two to get a response.
  • Emailed Kim a month ago. His response was:
    This is usually caused by a defective 47uF cap in the signal path.
    Digi-Key does stock a replacement capacitor.
    The part number is 495-6019-ND.
    Hope this helps.
    I followed up asking if I can send this anywhere and received no reply.
    Is Kim a Polk employee?
    Needless to say, this did not help solve my issue.
    F1nut Posts: 51,985
    He did help you, he told you what you can do to repair it. If you aren't comfortable doing that then take it to your local electronics repair shop.
  • I'm on my fourth PSW125 power amp in 9 years. I'm done.
  • Leif
    Leif Posts: 1
    Hi team.
    Anyone know who I can speak to over here in New Zealand to have this issue addressed? I see on a few other discussions people in the US have been calling the Customer Service team and seem to be having good luck with their replacements.
  • Send an email to: Kim.Jasper@soundunited.com and ask who to contact in New Zealand.
  • MikeUp
    MikeUp Posts: 86
    Wow, can't anyone make a subwoofer anymore. I see the exact same complaints for Jamo and Klipsch subwoofers.
    I have 2 sets of TL1600 speakers and both subwoofers have a hum with nothing plugged into them. They are just plugged into AC. Tried several rooms yet hum doesn't go away. I guess this is the norm as I read about this in several spots on the internet making this a "Normal" operation 'flaw'.
    I've had my Velodyne since the late 90s and have had older Sony and Yamaha subwoofers that never had issues.
    I guess now you get to pay more for the subwoofer and as an added bonus get all kinds of design and performance flaws.
    Makes me want to do what I did in the early 90s, have a tower speaker that plays down to 30s and route all bass to them and forget about having a subwoofer.
    On to new and better adventures
