LS50 bi-amp Upgrade
Hello, I am doing a bi-amp upgrade to my LS50 speakers, wondered if I should replace the existing crossover circuit. I was planning to drive the lower speaker as a woofer from the main amplifier, and drive the second 6.5" speaker (as a mid-range) with the tweeter with the second amplifier. Any thoughts on crossover frequencies for the LS50 cabinet?
Yamaha RX-V565
Polk LS50 modified with LS70 crossovers
Philips SBC-HP250
    F1nut Posts: 51,940
    For starters your speakers only have one set of binding posts. Proper bi-amping is a very deep hole, one that you don't want to go down.
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited January 2021
    What exterior xover do you have and what amps?
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • I will update my profile. Thx for reminder
    Yamaha RX-V565
    Philips SBC-HP250
  • DaveHo
    DaveHo Posts: 3,582
    edited January 2021
    So you swapped in crossovers from LS70's into your LS50's? Uhh, yeah, that's not the proper way to get bi-amp capabilities(Not to mention it's pointless on those speakers).
    What would really seal the deal on this experiment is to tell use you are going to bi-amp using a receiver.
