Hooking up passive subs
I have a couple of SVS passive subs I want to add to my system. I have an older Marantz SR7001 running my other equipment powered by a Sunfire 7400. I want to use my old Sunfire TGA5200 as a sub amp for both the subs (that's all that amp will be used for). I've used this configuration before but can't for the life of me remember how I hooked up the input for the subs, or what port I connected the speaker wires. Any suggestions?
My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus
(Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room
Best Answer
    Tony M Posts: 11,623
    edited December 2020 Answer ✓
    Yep...
    Page 14. ;)
    I think it will work great. B)
Answers
    pitdogg2 Posts: 27,050
    Subwoofer preouts from Marantz to sunfire TGA5200 amp inputs then speaker binding posts to sub speaker binding post.
  • hockeyboy
    hockeyboy Posts: 1,428
    Thanks Pit. The 5200 doesn't have sub binding posts. That's what's got me confused.
    My Main Gear
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    (Passive Subs)
    Panamax M5300EX
    hockeyboy wrote: »
    Sub binding post??
  • hockeyboy
    Apologies I guess I was asking which speaker posts to use on the 5200. Does it matter? The options are right front, left front, center, right surround and left surround. There are no posts for a sub.
    My Main Gear
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    (Passive Subs)
    Panamax M5300EX
  • DaveHo
    DaveHo Posts: 3,583
    No modern receiver powers a subwoofer. You want to use the sub preout(s) as @pitdogg2 recommended. If there's only one you'll need a splitter to feed both inputs on your Sunfire 5200.
  • hockeyboy
    Okay I do have a splitter so must have figured that out once before. But as far as the speaker wire posts from the Sunfire to the subs which should I use? I'm assuming the front left and right? Also assuming the same inputs that I am feeding from the receiver.
    Post edited by hockeyboy on
    My Main Gear
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    (Passive Subs)
    Panamax M5300EX
    I saw on line your Sunfire TGA-5200 has current and voltage terminals.
    The diagram shows which terminals should power the sub/s
  • hockeyboy
    The diagram suggests to use the voltage source for driving subs. That would imply to use the front left and front right channels since they are the only ones with voltage source outputs. I'll give it a try and let you know how it works. Thanks everyone!
    My Main Gear
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    (Passive Subs)
    Panamax M5300EX
