Found a CD player in my closet ....
gyosa
I forgot I had this ..
Thought I had discarded it.
Tray won’t open , can hear the motor trying....
I remember it was giving me trouble when I stopped using it 15 years ago or so ..
May be time to open it up and see what’s up ...
Bk
Bk
PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
Try some fresh grease that’s good with plastics on the drawer mechanism. I got some at a hobby shop and bought my dad’s old Marantz back to life after my Music Hall needed a new laser, and the first one ordered did not work either. The Marantz is still “temporarily” serving as my transport.
yep,
took it apart and looks like it needs some grease on the tray's rail....
appears to work fine other than that...
from what I remember , it was a very good player back in the day.
bkPS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO -
The tray belt is slipping, common problem.Political Correctness'.........defined
President of Club Polk -
Yes it is ...
It’s very loose ....
Also found my Nak CR-5...
Got it through the AAFES overseas catalog when I was in the AF...
I do know it needs all new belts...
Ha ha .... funny , haven’t missed these 2 a bit over the years .... streaming so much better ....
Hooked up the Denon to my 851n via coax .... plays great !
Weighs like 20 pounds ... LOL!
BkPS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
My Denon DVD-2910 just started having issues opening the tray today. Must be bad karma or just an old belt.Stan
Main 2ch:
HT:
Other stuff:
I just put a new lazar in my 3910 . Now it works again! $26Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
If you want the Nak to have a nice new home, I'm your huckleberry...
26 dollars? I'll take it.
PM sent...
Sorry the lazar was $36 shipped. Still worth the time to resurrect this nice dvd playerMain system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
My 3910 also needs a new laser.
My 2910 recently quit as well. Not sure what it needs...
Denon used very cheap lasers (Hitachi I was told) in most all to way to the totl. It will play most SACD/DVD-A but will choke on CD. My 2900 still works good but the drawer needs an adjustment as it fights coming open. I'm afraid I'm going to get an expensive SACD stuck in it, so it's resting
Yea those lasers at the time were like 10.00ea.
Maybe I'll youtube it one day and dive in 😂 -
I took the cover off mine , found a “tab”on the side that locks the tray....
Secured it “in” with a piece of tape so I can manually open and close the tray.
Other than that it seems to work fine , plays every cd I’ve tried in the last couple days...
Belts appear to be easily accessible, and are cheap on eBay - like 15 bucks - takes 2 of them.
I’ll get around to it someday .... honestly don’t really have a need to play cd’s anymore , though.
I noticed that Tidal sounds much better ....
