Need Serious Help! Asap! Now!
VR3
VR3 Posts: 29,437
edited March 2024 in Clubhouse Archives
Yeah! I need help...
Ok, we had a water valve break behind the washer, I have contained it by pipes to run into bowls, but dangit - I gotta go to sleep...
SO, I went outside and looked at the meter and the cut off switch...
For the life of me, i cant figure out how to shut off that effing thing...
It has a lil knof with an arrow... this arrowing is pointing to a big 'washer' with hand grips, if I turn it to the right - water starts to run out of it... is this normal? If I keep turning it to the right... will it shut off? DANGIT - I need help! PLEASE HELP!
  • Frank Z
    Frank Z Posts: 5,860
    edited February 2005
    Trey,
    Find the water main IN THE HOUSE and shut it off there.
    VR3 Posts: 29,437
    Where in gods name would that be????
  • Frank Z
    Check the Mech room where your furnace and water heater are. Do you have a water meter in the house?
    VR3 Posts: 29,437
    The main cut off switch for the house is out beside the road...
    the hot water heater is under the house...
    The main cut off switch is beyond me, I have no idea how to cut it off...
  • Frank Z
    Get your **** under the house and look for a single water line coming in through the foundation wall or up through the dirt. Follow it both directions and you should find a shut-off valve.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    There should be a square 'plug' on the street side of the meter, get the vice grips and shut it off. A quarter turn either way should do it.
    You'll know its off when the meter stops moving.
    VR3 Posts: 29,437
    What do I turn???
    THIS IS IT...
  • Frank Z
    Turn the knob with the arrow 90 deg. and your water should be turned off.
    VR3 Posts: 29,437
    man... guys...
    THANKS
    now I'm going to bed... jesus christ
  • Frank Z
    Bed?!? Aren't you gonna fix the leak?
  • Frank Z
    Resolved?!? What the F*** do you mean "Resolved"? The damn waters not leakin cause it's turned off, that ain't resolved! Somebody better get sorry **** outta bed...the job ain't done till the waters back on....and not leakin'!!
    Trey, you lazy little ****...get yer **** up and get the tools out! How the hell do you plan to amount to anything if you climb in bed when there's work to be done?
  • pjdami
    pjdami Posts: 1,894
    Carpentry and woodwork the kid has been impressive with.
    Plumbing 101 he recieved a good lesson tonight. I'm assuming he is going to sleep to get to school tomorrow.
    What about the water heater? Depending if it totally drained it could be a problem too. I would want to shut it down until water pressure is restored.
    F1nut Posts: 51,787
    Good point on the water heater.
    FWIW, there are suppose to be a shut off valves for the hot and cold water lines just before the hose connections to the washer.
  • brettw22
    brettw22 Posts: 7,623
    Showering in the morning will be a ****.......
    VR3 Posts: 29,437
    That is what was leaking! ;)
    Unfortunately, we dont know of place to go at 1am to find a replacement valve...
    And.. I had to go to bed, school.. yeah
    I can replace heating elements, and faucets, and thermostats...
    BUT :o this is a bit beyond my field of expertise eh ;) - I couldnt rightfully assure you that if I fixed the valve or installed a new one, that as soon as we turn on the water... there wont be a WORSE leak... ha! lol
  • Demiurge
    Demiurge Posts: 10,874
    Just curious why this is a 16 year olds responsibility.....
    Where's your dad, etc?
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Trey,
    A water value has a nut looking thing under the knob is what leaking? If so easy fix just try to tighten some a slight turn will do, it will be easier then replacing value.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Frank Z
    Humor is lost on some.
  • avelanchefan
    avelanchefan Posts: 2,401
    i got it frank, and i LMAO!!
    My pnly question is where's Mom and dad??
    Sean
    XboxLive--->avelanchefan
    PSN---->Floppa
    http://card.mygamercard.net/avelanchefan.png
    VR3 Posts: 29,437
    My Mom dosnt know anything about this, I am looked at to fix things around the house, and my sister dosnt do anything except make life harder around here...
    My Dad moved out in 1995, he lives 30-40 minutes away, and I havnt really held a conversation with him for about 6-7 months now...
    I tried tightening the valve, which it did tighten alot, but the leak did not stop, it actually got worse..
    And since I had no luck with local people helping us, I finally thought to post on here about 2 hours later...
    by that time, I had compiled a contraption - I ran a pipe to the valve, for the water to run down into a bowl...
    This was alot better than it running down into a wall..
    Fun fun fun...god I was tired today!
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    Glad Frank and the Gang were there for you!
    If you replace the hose bib (valve) for the washer yourself, be mindful of what it may be screwed into. If it's a copper or plastic piping system, put a holdback on the copper or plastic fitting that the hose bib screws into. A hold back is a wrench going the opposite way of the direction you are turning the valve (counter clockwise to loosen..... remember "righty tighty and lefty loosey.") If you don't hold back the torque exerted on the valve you're removing, you'll end up with worse problems to fix. Reverse the hold back when you tighten the new valve as well. Same principal applies.
    Good luck! You're well on your way to a master's license. As soon as you learn that crap doesn't run uphill and Friday is payday, you're there! ;)
  • Tour2ma
    Tour2ma Posts: 10,177
    There is packing/ washers under the valve stem's nut that can be replaced...
    Still have to be careful of torquing the valve as BMDP indicated...
    More later,
    Tour...
    Vox Copuli
  • Demiurge
    Oh, I wasn't sure where you were at.....Didn't mean to tread on a crappy situation. I've been through it myself.
    Either way dude...you should definitely get someone who is liscenced to deal with this stuff because you can end up creating huge problems if you mess up. Good on shutting off the water though...I just kind of wondered why YOU were the only one dealing with this. :)
    VR3 Posts: 29,437
    We are trying to get a plumber out here, but alas... they didnt make it today - what a surprise...
    VR3 Posts: 29,437
    I've had some requests to see what I did to take the leak and put it in a bowl... ha
    so here it is...
    had to empty that bowl about 4 times in 1 hour...
  • audiobliss
    audiobliss Posts: 12,518
    haha....I'm certainly glad you didn't end up having to empty that bowl 20 times.....lol
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • Frank Z
    Mind if i save you some cash, aggrevation, and another flood later?
    1) The valves are easy to replace. Get down to the hardware store and buy 2 BOILER DRAINS or 2 MIP x hose valves, 1 small roll of teflon tape and swap 'em out yourself. The valves you have now are threaded, piece of cake, just use a back-up wrench so you don't twist the pipe. You already know how to turn the water main off so your ready for action Jackson!
    2) While you're at the hardware store, pick up some Stainless Steel braided hoses for the washer. Imagine the mess you'll have when those rubber hoses rupture (and they will). Now imagine the mess if it happens when no one is home. One of my customers had this happen to hers. Washer was on the upper level and she ended up with a foot of water on the main floor.
    VR3 Posts: 29,437
    Very good advice there about the rubber hoses...
    I *really* prefer a pro to change the valves, as I dont trust myself with it, I just dont have the knowledge to give it a try...
  • gwh
    gwh Posts: 1,451
    Just add Everclear, then you have cowboy koolaid, right?
    HT:
    Martin Logan Motion 40
    Martin Logan Motion 50XT
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Def Tech Reference Sub
    Yamaha RX-A3070
    Signal Cable speaker wires & interconnects.
