parasound amp repair
Does anyone know anyone around the Kansas City area that works on parasound amplifiers?
or power amplifiers for that matter.
i think i have an issue with a toggle switch that might need to replaced or by passed.
HCA-3500
i get a bit more noise on one channel and periodically that channel gets a scratchy sound that seems to be alleviated by moving that toggle switch (to switch between balanced vs unbalanced) around.
  • skrol
    skrol Posts: 3,456
    edited December 2020
    If you are able to DIY, send Parasound an email. They are really good at getting back to you and putting you in touch with their technical folks. Don't be surprised if Richard Schram, the company president, emails you back.
    Email them anyway. They may be able to tell you where you can get it fixed.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • thejck
    thejck Posts: 849
    I have had Richard respond to me in the past. i might do that. thanks.
  • gp4jesus
    gp4jesus Posts: 2,019
    DIYAudio if you trust yourself
    *all connected w/Premiere ICs
  • adb3da
    adb3da Posts: 507
    I know a shop in St. Louis that is an authorized Parasound service shop, if you ever find yourself traveling over on this side of the state.
  • soundfreak1
    soundfreak1 Posts: 3,414
    If you are to service amp go ahead and replace the output relays. They will probably recommend it but if not do it anyway.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • thejck
    thejck Posts: 849
    can you tell me more about this?
  • thejck
    thejck Posts: 849
    i did find a couple of places in KC that can and will work on it. audiomart is 3 months wait and kcstereorepair is 5 months wait
  • thejck
    thejck Posts: 849
    thejck wrote: »
    can you tell me more about this? i can plan to have this done when i get it to a shop or is it something that can be diy'd
  • Do you know if Big Sky Audio is still in business for restorations/upgrades? Think he used to be on the DIY forum. Heard he was also authorized for Parasound. A hefty shipping cost to Montana, but heard good things. Pardon the puns.
  • soundfreak1
    Diy is up to you, you know your abilities
    The reason is the hca series had an issue with those relays as they age. if I do any service I replace while it's being done so I dont have to open it up again and do it.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • DaveHo
    DaveHo Posts: 3,582
    Owner of Big Sky retired.
    pitdogg2 Posts: 27,163
    DaveHo wrote: »
    Plus his site said he no longer worked on the 3500 when he was open for business IIRC. Too heavy for him to handle.
  • DaveHo wrote: »
    DaveHo wrote: »
    Thanks guys.
