parasound amp repair
thejck
in Electronics
Does anyone know anyone around the Kansas City area that works on parasound amplifiers?
or power amplifiers for that matter.
i think i have an issue with a toggle switch that might need to replaced or by passed.
HCA-3500
i get a bit more noise on one channel and periodically that channel gets a scratchy sound that seems to be alleviated by moving that toggle switch (to switch between balanced vs unbalanced) around.
HCA-3500
If you are able to DIY, send Parasound an email. They are really good at getting back to you and putting you in touch with their technical folks. Don't be surprised if Richard Schram, the company president, emails you back.
Email them anyway. They may be able to tell you where you can get it fixed.Stan
Main 2ch:
HT:
Other stuff:
I have had Richard respond to me in the past. i might do that. thanks.
DIYAudio if you trust yourselfSamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
I know a shop in St. Louis that is an authorized Parasound service shop, if you ever find yourself traveling over on this side of the state.
If you are to service amp go ahead and replace the output relays. They will probably recommend it but if not do it anyway.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
soundfreak1 wrote: »If you are to service amp go ahead and replace the output relays. They will probably recommend it but if not do it anyway.
can you tell me more about this? -
i did find a couple of places in KC that can and will work on it. audiomart is 3 months wait and kcstereorepair is 5 months wait
can you tell me more about this? i can plan to have this done when i get it to a shop or is it something that can be diy'd
Do you know if Big Sky Audio is still in business for restorations/upgrades? Think he used to be on the DIY forum. Heard he was also authorized for Parasound. A hefty shipping cost to Montana, but heard good things. Pardon the puns.
Diy is up to you, you know your abilities
The reason is the hca series had an issue with those relays as they age. if I do any service I replace while it's being done so I dont have to open it up again and do it.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Inscrutabl0915 wrote: »Do you know if Big Sky Audio is still in business for restorations/upgrades? Think he used to be on the DIY forum. Heard he was also authorized for Parasound. A hefty shipping cost to Montana, but heard good things. Pardon the puns.
Owner of Big Sky retired. -
Owner of Big Sky retired.Inscrutabl0915 wrote: »Do you know if Big Sky Audio is still in business for restorations/upgrades? Think he used to be on the DIY forum. Heard he was also authorized for Parasound. A hefty shipping cost to Montana, but heard good things. Pardon the puns.
Plus his site said he no longer worked on the 3500 when he was open for business IIRC. Too heavy for him to handle.
Thanks guys.
