Panasonic SX 205 receiver
storefixx
I have a Panasonic SX 205 receiver. I need to know if it has an internal pre amp. The receiver and turntable have been is storage for @ 5 years. When I play a record, the sound is VERY faint. If the receiver has a pre amp then I probably have a bad cartridge or needle.
Answers
Have you heard of Google?
I can find a Pioneer Sx 205 but not a Panasonic, are you sure that's what you have?
Regardless of the receiver brand it will have a pre-amp built in. Which input on the back of the receiver did you connect the turntable to?Political Correctness'.........defined
President of Club Polk -
He might be referring to a "phono preamp".
The Pioneer SX-205 does appear to have a phono preamp -- FWIW.
manual available @ hifiengine -- free registration required to d/l
https://www.hifiengine.com/manual_library/pioneer/sx-205.shtml
@storefixx what phono cartridge are you trying to use?
Now, and again FWIW, there was apparently (!) a Technics (Panasonic's hifi brand) SA-205
seems very similar, at least cosmetically, to the SA-203.
https://www.hifiengine.com/manual_library/technics/sa-203.shtml#
I don't see too much info online on the SA-205, but this thread suggests that it does indeed have a phono preamp onboard.
https://audiokarma.org/forums/index.php?threads/technics-205-receiver-problem.770821/
