What receiver should I look for for my older Series 2 monitor surround?
I bought a house with an awesome, pre-wired, Polk surround system. There is right, center, left, and 2 mounted surrounds. Previous owner has all the wires separated beautifully and I would like to tap into this. I just want to be sure whatever Amp I buy will be compatible with these speakers 🔊. Thanks! My hope is to buy something second hand but good enough.
Best Answers
    Viking64 Posts: 7,708
    Answer ✓
    Please twist the ends of that stranded wire or you know what will happen.
    F1nut Posts: 52,164
    Answer ✓
    Better yet, terminate the wires with banana plugs. Do NOT play those speakers without addressing that wire disaster.
    You want an AVR not an amplifier since it is a surround speaker system. Your budget will determine which AVR.
Answers
  • BlueFox
    BlueFox Posts: 15,250
    LOL. I didn't notice that disaster. :)
  • RifleMan
    Thanks guys. I now have a clue and will fix those wire ends before any power goes through them. Good catch!
  • RifleMan
    I Googled AVR receivers. More research to come. Just getting started on this project.
