Command Bar crackling
Hammer686
Polk command bar worked fine for 6 weeks, started crackling out of sound bar, audio sounds like talking under water. Tried power off/on, factory reset, disconnect HDMI ARC and relocating. Crackling sound as soon as power on with no input. Any ideas?
Hello,
I recommend sending an email to: kim.jasper@soundunited.com and explain what you're experiencing. -
I have the same problem. But, now the left side makes almost no sound.
See post above... -
Either of you get an answer from Polk?
