Command Bar Subwoofer not pairing
AntoSara
Hi all,
Bought Command Bar 20 days ago and it works fine.
So, I don't know why and when, two days ago I see (and heard) that the sub doesn't work and it seems that it lost pairing with the Soundbar (that continues to work fine).
I try to re-pair, but it doesn't work.
I try to syncronize them in any way. With my home wifi off, shut down soundbar and subwoofer and put on first the soundbar and after the sub. Nothing.
I don't see any indications or Faq for this problem?
May you help me please?
Hello,
Contact kim.jasper@soundunited.com and explain what is happening. -
Polk Command bar subwoofer will not sync no matter what I do..PLEADE .HELP, or the local dump is getting a new deposit...
twiztedangel wrote: »Polk Command bar subwoofer will not sync no matter what I do..PLEADE .HELP, or the local dump is getting a new deposit...
Read the post above yours.
