LSiM 702 FX speakers 299.99 a pair
vmaxer
vmaxer Posts: 5,121
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
    msg Posts: 10,508
    Ha, beat me to it, I was just coming on here to post this as well!
  • vmaxer
    vmaxer Posts: 5,121
    msg wrote: »
    I can’t believe this price.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Dabutcher
    Dabutcher Posts: 2,606
    Beat me to it. Great deal.
    Love yours. D
  • Dabutcher
    Just ordered four to replace my FXi6 pair and RTi12 rears. Both of these will be up for sale. Local pick up only.
    Love yours. D
    msg Posts: 10,508
    I finally broke down and ordered a set, too. I've been on the fence over various deals for four or five years.
  • afterburnt
    afterburnt Posts: 7,892
    I just ordered these because they are cheap. What do they do?
    msg Posts: 10,508
    ^^^ LOL
  • pawelmwo
    pawelmwo Posts: 137
    edited November 2020
    Don't tempt me Frodo!
    Update: Ordered a pair :blush:
    Post edited by pawelmwo on
  • delkal
    delkal Posts: 764
    What are these? Did Polk and Bose have a baby?
  • simm
    simm Posts: 604
    I ordered a pair as well and got them today. Going to have to set up a 7.1 system now.
    mhardy6647 Posts: 35,335
    delkal wrote: »
    More like the AR-MST (which were, in essence, baby AR-LSTs:
    Or the EPI M-601/M-602:
    Or the KLH Twenty-Eight:
    heh, or the Allison Four:
    so...
    Are these LSIm -702fx thingies useable as "mains" (i.e., for 2-channel) or are they only good for surround use?
  • rooftop59
    rooftop59 Posts: 8,120
    @mhardy6647 i only had a pair for a brief time, but I would say definitely only surround use!
    That’s an impressive list! I had no idea!
    Game Room 5.1.4:
    Bedroom 2.1
  • dromunds
    dromunds Posts: 10,152
    If a person already has a pair of LSi-FX would 702’s be advisable?
  • dromunds
    That is, would the 702’s be a worthy step up from the LSi-FX at $299/pair with free shipping?
    rooftop59 wrote: »
    Heh. Thanks -- heck, even I can find better ways to p!$$ away 300 smackers.
    It was a thing :)
  • Emlyn
    Emlyn Posts: 4,846
    dromunds wrote: »
    I would call them a sideways step depending on the rest of the speakers in the system. The LSiFX are excellent surround speakers that would still fit into an LSiM system for surround use sound wise but not perfectly. The designs are really quite different. If all the other speakers are LSiM I would jump on the LSiM 702s at the price they are at. Note the size differences between them though. The LSiM 702s are quite big (wide) even compared to the LSiFXs. But, the LSiM 702s stand out less from the wall because they are bottom ported.
    Post edited by Emlyn on
  • afterburnt
    Will FXI A4's make good height speakers, I got a couple of spares?
  • pawelmwo
    pawelmwo Posts: 137
    I see from the manual the placement for a 5.1 setup recommends sides versus rear. Although in 7.1 has placement in the rear for the 702's. I purchased these based on the price but might not have the proper placement for them. How off would these be if replacing two Fxi A4's on stands in Bipole mode behind the main listening position? Ultimately might sell them but the price was too low to pass up.
  • WLDock
    WLDock Posts: 3,073
    dromunds wrote: »
    @Emlyn made some great points. I agree that if one were to run a full LSiM setup then it would be cool to have the 702's.
    Myself, I've used the Polk f/x 500i and f/x 1000 and found both to be awesome for surround duty. The LSi-FX would be really hard to top for those needing a dipole/bipole speaker. The 702's might be better for discrete channel object based sound used in Dolby ATMOS systems for example. Dipole/bipole speaker ARE NOT recommended.
    I love the split cylinder shape of the 702's for surrounds and for years have strongly considered getting them. However, my couch sits right at the rear wall and the left side of the room is open to the kitchen. So, side surrounds are not an option and IMO dipoles work better at diffusing the effects. With the 702's being direct firing, I'm not sure how well they would work over the split cylinder shaped Artison Portrait LRS that I already have on the back wall. Also, they are almost twice as large and almost three times as heavy! At the given price, its now or never to get a set but I talked myself out of them again. :smile:
    702 f/x
    19-15/16 W x 16-1/4" H x 6-3/4" D
    28.9 lbs
    Artison Portrait LRS Surrounds.
    9-3/8" W x 9" H x 4-1/16" D
    10 lbs.
    The Artison's are pretty cool play fairly well and clean beyond their small size yet produce a well defused sound. They have Kevlar drivers, Vifa tweeters and the design was headed by Cary Christie formerly of early Infinity Systems, Inc and Acoustic Research fame. They are dipole from about 3k Hz only.
    pawelmwo wrote: »
    Dolby recommends a Dipole speaker (FXi A4) for the side and a direct firing (702's) for the rear. However, some use diople or bipole for a 7.1 setup for other formats. Then, there are the modern object based formats like ATMOS that recommend direct firing speakers closer in height to ear level. One has to find what works and sound best in their own space.
    Post edited by WLDock on
  • afterburnt
    afterburnt wrote: »
    No Afterburnt, you should just throw them away.
  • rooftop59
    afterburnt wrote: »
    afterburnt wrote: »
    I do think that Dolby recommends direct radiating speakers for heights, but ya know what they say: trust yer ears and all that...
    Game Room 5.1.4:
    Bedroom 2.1
  • afterburnt
    rooftop59 wrote: »
    afterburnt wrote: »
    afterburnt wrote: »
    Donkey Shame.
  • stangman67
    stangman67 Posts: 2,330
    Thanks! Ordered a set to compete my 707/706 setup in my Man cave/bar
    Post edited by stangman67 on
  • Dabutcher
    People can also order on Amazon for same price. Might have a better return policy?
    Got my four yesterday. One dent in box. Will open them and test tonight.
    Love yours. D
  • pawelmwo
    pawelmwo Posts: 137
    Dabutcher wrote: »
    Love yours. D
    It's not sold by Amazon though but CAPITOL HOME THEATER. Don't think they are an authorized reseller so YMMV
  • Emlyn
    Emlyn Posts: 4,846
    I got a pair from Crutchfield even though I don't need them right now. Next time I move I may go back to a 7.1 system with the 702s as side surrounds. Their return policy is the best in the business if needed. :)
  • Dabutcher
    Great to know that Crutchfield return policy is solid. Thanks. D
  • Emlyn
    Emlyn Posts: 4,846
    Had one pair delivered by UPS today. That 62 pound box is solid!
  • Dabutcher
    I am having trouble with set up of four new 702’s. My HT room is 12’ wide by 30’ long. So I cannot mount on back wall. Too far away
    Instructions call for mounting like B or only use two and go with C. They are directional so hence the arrows. I would like to go A.
    As always. Any and all help would be greatly appreciated. Peace. Dxtm0bhf0j9bu.jpeg
  • gurot1
    gurot1 Posts: 519
    Turns out they don't ship north of the border and crutchfield.ca not have them. One of these I will snag a deal on these. Congrats to those that were able to get them at this awesome price!
    lsim705,lsim706c,lsif/x(4)+mc80(atmos)
    rti6,csi5,fxi5
