JPEG pix
PETERNG
Anyone know any DVD player that will play JPEG pix burned on CD? (other than the APEX). Thanx...
Post edited by PETERNG on
You wanna look at all your nuddy pictures on a 60" screen, huh Pete?
Aaron -
Nuddy?
You mean Nudie?
RCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
i hope he meant nudie, and not nutty...:D
I'm not sure exactly what you're going for, but I used this program to turn pictures from my digital camera (JPG's) in to slide shows, which you can then burn on to a normal CD-R. It basically creates a VideoCD, so the only requirement your DVD player would have to have is to be able to play CD-R's and VCD's. It's easy to add music and change the menu system, too.
Hey, I wish I have some of the nuddy things so I sent them to Troy... Dylan speaks on my behalf, I know the new Apex DVD player will play JPEG, hell, they have the model can also play both SACD and DVD-A, but I want something better than APEX, just want to make sure...:rolleyes:
They probably look fantastic on the 60" WS big screen, thanx for the idea Aaron...:p -
There's a difference between JPG and J-PEG. I don't know what it is, I'm just POSITIVE it's there. I up-grade slow. My first DVD player is < 2yrs old, my only 5.1 rcvr is <1yr old and my computer is W95.
APEX! Let's see: A player that can do DVD, CD, DVD-A, CDR, CDRW, SACD, MP3 & J-PEG (maybe JPG) at an affordable (almost disposable) price. You're right, stay away. After all, they offer usable features at an affordable price, but their new. I'm sure their digital-outs are made of rhinestones and plexi-glass.:pMake it Funky!
I use a Panny RP-91 and burn vcd mpg's converted from jpg's and they look good on the 65" Mits. There is a freeware version of a vcd program that converts and burns the vcd's.
