Nice Outlaw M 2200 mono block 200 watt amps A Pair
Nice Outlaw M2200 mono block amp I have two of these for sale In excellent shape and works as they should. Includes original double box, upgraded power cord and copy of manual Very well built and great bang for the buck sound wise as Outlaw gear tends to be.
Asking $299 each or both for $575 Thanks
Okay, so you want big power but you need greater flexibility. Well, the Model 2200's are just that, powerful AND flexible! The Model 2200 is a single channel 200-watt amplifier. You simply buy one for each speaker. Like our other 200 watt amplifiers, this amp will drive virtually any speaker or (passive) sub you throw at it. So what about space you ask? Each Model 2200 sits just under two inches tall so you won't need to buy a new equipment rack! The Model 2200's advanced circuitry and large pancake style torroidal transformer enable us to deliver a cool yet potent performance. In addition to its sleek design we have provided a special signal sensing circuit that triggers the amplifier to power on whenever an audio signal is present. The Model 2200: small, sleek and powerful-need we say more?
Specifications
Power Output: 200 watts @ 8 ohms, 20 Hz - 20 kHz, <0.05% THD; 300 watts @ 4 ohms, 20 Hz - 20 kHz, <0.05%
THD Signal to Noise: 112 dB "A" weighted
Input Impedance: >10K Ohms
(RCA=16K Ohms, XLR=30K Ohms)
Gain: +27dB for full output
(1.7V XLR input sensitivity)
(850mV RCA input sensitivity)
Input Connectors: RCA Jack, XLR Jack
Output Connectors: Five-Way Binding Posts
Power Consumption: 600 watts maximum/<3 watts standby
Trigger Input: 3-35 V DC 4mA
Weight: 18 pounds
Dimensions (H/W/D):2" with feet x 17" x 12"
