Entry level turntable recommendation
I am looking to get the GF an entry level turntable for around $250.
She has a Yamaha R-N303 that has a built in phono stage and Polk Signature 15s. Looking for analog connectivity not Bluetooth or wireless.
Want to go with new as it will be a gift.
Thanks.
Living Room
Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
Office
Yamaha A-S501, Auralic Aries Mini, LSiM 703s
Douglas Connection ICs and Cables
  • Dr_Wu
    Dr_Wu Posts: 356
    I can recommend the Audio Technica LP-3 for an automatic turntable, $200 at the moment. The built-in phono preamp can be bypassed using a switch on the back panel. Lots of cartridge upgrade options if she doesn't like the AT91R.
    Clipdat Posts: 13,100
    Oh yeah, good call. Forgot about Fluance.
    edited October 2020
  • jdjohn
    jdjohn Posts: 3,384
    The Music Hall MMF 1.3 is $299.99 if you could stretch, but otherwise, I like the Fluance.
  • +1 on the Fluance
    msg Posts: 10,473
    I'd definitely go with something with a non-hollow-plastic deck to minimize noise. When I got my first table I thought I'd give the AT-LP120 a try, but I could hear everything through it. Sent it back and decided vinyl wasn't for me. Then a year later I got bit again. Maybe other such tables are better damped now. I think the Pioneer one is, but it's not in that budget range.
    Took me a while to learn to love the "audiophile" type designed tables. I initially really liked the Technics 1200 type tables, which is what I have, but I tried a Pro-ject Debut Carbon thanks to a good buddy, and it really grew on me.
    +2 on the Fluance.
    I kinda like the u-turn, too.
    gudnoyez Posts: 8,174
    U-Turn offerings for your budget should be a good choice.
  • displayname
    displayname Posts: 1,236
    I had a UTurn before upgrading, and we still have one in the dining room.
    I will note that the acrylic platter upgrade is totally worth it, and changing the belt to 45 rpm is a bit of a pain.
    For ease of use, I'd go Fluance. For ability to do some upgrades, go UTurn.
    Discogs
  • These all sound like viable options. Any downside to belt vs direct drive?
    Living Room
    Office
  • Milito
    Milito Posts: 2,003
    edited October 2020
    I have the Fluance RT85 which I really like for a budget turntable.
  • those wood platters of the AT and Fluance look pretty cool
    Living Room
    Office
  • displayname
    Belts wear out over time. DD can be audible, but that's generally system dependent.
    At the entry level I think you get a little more from belt drive because they are less expensive to design and build so that money can go to other parts. But plenty of people are very happy with AT LP-120.
    Discogs
    mhardy6647 Posts: 35,242
    edited October 2020
    Oh, man that's like asking folks about their choice of religion or political party ;)
    ... and, of course, there's always idler drive. :#
    EDIT: FWIW, I would bet money* that the A-T and Fluance tts above are both made by the
    same OEM. I'm guessing they're both made by Ya Horng, but that is a SWAG.
    ___________
    * Not much money... but money. Howzabout a quarter? B)
  • Dr_Wu
    Dr_Wu Posts: 356
    I wouldn't take that bet. And, you could throw the Denon DP-300f into that mix.
    edited October 2020
    FWIW, the U-Turn was (is) a valiant and laudable attempt by a small, enthusiast company to "do" a high-value, US-made tt from the ground up. It was a big, big deal when it debuted (if memory serves, it was a Kickstarter project) and the small (tiny) company quickly got a reputation for exemplary customer service & support.
    My only 'gripe' about the U-Turn is a certain perceived crudeness to it (especially the arm) that I assume stems from its "greenfield" design and very modest price. They have a good reputation "in the field", though, so my perception ain't worth all that much! ;)
    In all seriousness, I would expect either the A-T or the Fluance tt above to be good, and for the $, good is... well... good. :) I would have to think either would track a decent cartridge, properly installed, well enough to provide very satisfying playback of rekkids -- and I don' t mean to be damning with faint praise by this comment! I would think that either would easily be (at least) the equal of, say, a Sansui SR-222, Technics SL-B1, Pioneer PL-512, etc. in terms of getting the job done... and all of those tts got the job done perfectly well.
    9931769165_62686928af_c.jpg313%20and%20it%20cooks by Mark Hardy, on Flickr
    Heck, there's still a PL-512 here; I think it's great :)
  • jdjohn
    jdjohn Posts: 3,384
    I agree, the arm looks a little cheap, but I will give them props for placing the counterweight in the same horizontal plane as the stylus. That is a common feature in the design of some more expensive arms...not to mention the good ol' AR XA B)
    I also agree with @displayname about the acrylic platter. It is much better than the common stamped platters out there. FWIW, the Music Hall has a cast-aluminum platter, but the Fluance is the heaviest tt overall out of this bunch by a couple of lbs, and that should not be overlooked.
    jdjohn wrote: »
    Yup, I was gonna mention that, too -- but I got tired of typing. :#
    msg Posts: 10,473
    Gettin' slack, Doc (ಠ ͜ʖ ರೃ)
  • decal
    decal Posts: 3,205
    https://www.musicdirect.com/turntables/music-hall-usb-1-turntable
    This is a great starter for a dang good price.
  • Milito
    Milito Posts: 2,003
    edited October 2020
    Here's a pic of my RT85 when I first got it and was making sure it worked before I put it in my entertainment center below.
  • Appreciate all the recommendations, was leaning towards the Fluance but ended up with the AT. I think she will love it.
    Living Room
    Office
  • afterburnt
    afterburnt Posts: 7,892
    Milito wrote: »
    Funny, we watch the same thing on TV
