Benchmark LA4 preamp and AHB2 power amplifier review
  • SIHAB
    SIHAB Posts: 5,825
    invalid wrote: »
    Does benchmark use the THX feed forward type of feedback in this amp, and if so what are the advantages of it?
    70-100 usable watts of distortion-noise free A-B power.
  • kevhed72
    kevhed72 Posts: 5,223
    jdjohn wrote: »
    Nice work, Drew B) Definitely worth considering, although for my purposes, I think one of their DAC2/3 HGC models is probably where I would land for a preamp.
    Why so....and thanks for putting this idea in my head 😂
  • kevhed72
    edited October 2020
    Clipdat wrote: »
    I need this combo back in my life. :pensive:
    Seriously missing it.
    So Drew it appears the amp has the option for one or two subs via the 3 Speakon connectors...is this correct? Excellent review BTW!!
    Clipdat Posts: 13,104
    I'm not sure, but I believe you likely could as all speaker outputs should be active simultaneously. Best to email Benchmark and confirm though. sales@benchmarkmedia.com
  • jdjohn
    jdjohn Posts: 3,441
    edited October 2020
    kevhed72 wrote: »
    jdjohn wrote: »
    I done went and did it a few weeks ago:
    I hate to break-up my PSA stack, but we'll see.
    I like the integrated DAC on the DAC3/HGC, as well as the headphone outputs...yes, there are two in case you need it B)
    EDIT: I'm wondering if anyone here (or elsewhere) has tried an A/AB power amp with this preamp.
  • kevhed72
    The DAC2 with the Benchmark amp is what I am pondering. Use the DAC2 as the volume control. The amp is small in stature and weighs 13 lbs, which is interesting.
  • jdjohn
    jdjohn Posts: 3,441
    Not the best arrangement, but finally trying this combo:
  • joecoulson
    joecoulson Posts: 4,979
    Interesting
    Thoughts from first night?
  • jdjohn
    jdjohn Posts: 3,441
    Very pleasantly surprised. It was a real PITA to swap-in the DNA-125, but it was worth it. I really need to get a better rack.
    Anyway, the sound has more heft and authority with the McCormack, and with the crystal-clear sound of the Benchmark, it is turning into a really nice combination. This setup is throwing a big soundstage that is wider, taller, and deeper than with the PSA S300. The S300 is very forward, which I have an appreciation for in my listening space, but so far I'm thinking the DNA-125 just fills the room better. More listening will help confirm that, and maybe get my wife's opinion as well.
    I am noticing that the McCormack seems a little slower, yet more lush, but the speed thing is obviously just in comparison to the PSA class-D design, which is very quick and tight.
  • joecoulson
    Great thoughts. And not too far from my own changes.
    Hope all is well Jody.
  • verb
    verb Posts: 10,176
    jdjohn wrote: »
    Awesome amp! I've got one of those lying around here somewhere! :)
  • verb
    verb Posts: 10,176
    Love the review Drew! Since I've known you, I have learned to trust your ears.
    Gosh every time I read one of your reviews I have to resist getting out the CC! :)
    Well done sir!
    Thanks Dave! Glad you enjoyed the review.
  • SIHAB
    SIHAB Posts: 5,825
    Did you use balanced interconnects Clip?
    What amp setting did you use?
    edited October 2020
    Yes I used balanced XLR with the amp sensitivity switch set to the bottom Low-Gain = 22 dBu (9.8 Vrms) position.
  • SIHAB
    SIHAB Posts: 5,825
    I've found I like the middle sensitivity setting usually when using
    the DAC2. When using a pre in HT-bypass the lowest setting
    all the way.
  • jdjohn
    jdjohn Posts: 3,441
    The jumpers definitely need to be experimented with on the DAC3/HGC for XLR output, depending on the power amp.
    "Once I heard the Benchmark LA4 preamp and AHB2 power amplifier, I thought, “This could be my last preamp and amplifier purchase, ever.”"
  • maxward
    maxward Posts: 1,742
    The Absolute Sound named the LA4 solid state preamp of the year, so your review seems to be corroborated by those guys.
    Christmas came early!
  • gyosa
    gyosa Posts: 770
    Sweet !
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
    Gorgeous!
  • Milito
    Milito Posts: 2,003
    Congrats Drew!
  • jdjohn
    jdjohn Posts: 3,441
    Will this be your "last" as advertised? ;)
    It could be.
    Looking good in black!
  • maxward
    Looks great, Drew!
  • SIHAB
    SIHAB Posts: 5,825
    now that you have had it for a couple of hours... :)
    Does the LA4 really do nothing at all to the sound?
    Thanks either way.
  • tophatjohnny
    Congrats Drew ! Looks sweet !
