Will a Adcom GFA-555 amp be enough power to push a set of SDA SRS 2.3 speakers?
I just bought a set of SDA SRS 2.3 off a man on facebook, they look like new and are all original. I try running them with a Onkyo 100 watt a channel receiver - the results was flat sound and no bass at all. All drivers were putting out sound, so is my problem not enough amp or do you think they need to be recapped or all the above?
Best Answer
Answers
    pitdogg2 Posts: 24,481
    The adcom will work. But both are long in the tooth in the cap dept.
  • Thanks, any suggestions on the recap replacement. I can replace the capacitors my self but are there upgrades or should I replace them with the original values except upgrade them to Dayton or Sonic Crafts?
  • invalid
    invalid Posts: 1,271
    Sonicap is what most use in the Polk crossovers, but clarity are also a good choice.
    VR3 Posts: 27,970
    I believe he means the amplifiers
  • Nightfall
    Nightfall Posts: 10,042
    Have you done the PR/air leak test? What size room are they in? How far from the back wall are the speakers?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • polrbehr
    polrbehr Posts: 2,825
    I think something else is amiss here; those speakers should not sound flat or have no bass just because you're using a 100W receiver. I drive my SDA 2B with a mere 60W Adcom and I have no such complaints.
    Is everything original to the speakers? What about the interconnect cable? @Nightfall has some good points as well.
  • invalid
    polrbehr wrote: »
    Totally agree, my 2a's had bass with a receiver but when I got a dedicated amp (which was the adcom gfa555) the bass was just much better and controlled.
  • My room size 22 x 26 with a cathedral ceiling. They are placed about 6" from the wall in the back and 4' from the wall on the left side, 7' apart from each other. They are all original including the crossover capacitors. I'm not sure what the PR/air leak test is but if I pus the passive radiator all the bass drivers move in and out with it. Also I was mistaken about my receiver it's 60 wpc instead of 100 wpc. Hope I'm answering everybody questions! I've also have a set of SDA 2b and they also lack bass hooked up to this receiver. I'm in the process of ordering capacitors for the SDA 2b right now and going to upgrade them to the RD0194 tweeters. Now my Polk M4 sounds great on this receiver but they are a lot smaller also.
    edited October 2020
    Place them closer to the wall, mine are less than 4" off back wall.
    Passive test is
    1. push quickly in until bottoms out and hold there and watch mid-woofers hold until MW are back at resting position
    2. count time it takes MW to recede to resting position
    3. the longer the better report back
  • Schurkey
    Schurkey Posts: 2,100
    Move the seating position. You may be listening in a null region within the room. Your room is nearly square--except for your ceiling, that room would be terrible with standing-waves. About the only way it would be worse would be a flat ceiling that's about 8' high.
    The '555 Adcom is well-regarded, but the caps will be far beyond their service life. Could easily result in poor bass due to power-supply degradation.
  • engie490
    engie490 Posts: 425
    Schurkey wrote: »
    Agree with first statement. Play some bass heavy tracks and walk around the room and see if you notice any changes in the bass response.
    On the second statement, older Adcom amps are notorious for the smaller electrolytic caps leaking on the boards and ruining them. You should have those caps replaced even if they are still good. Fortunately, that should not be too expensive.
    The main power supply caps (aka the beer can size ones you can't miss) should be measured by a competent tech to determine if they need replacement. My Threshold Stasis 2 has plenty of bass and appears to have the original main PS caps from 1978! Of course, YMMV...
    Sonus Faber Liuto / Coda Continuum / Anthem STR Preamplifier / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Ikeda 9C2 & Dynavector XX2 Mk II carts
  • Schurkey
    engie490 wrote: »
    Make sure that "Tech" measures both the capacitance AND the ESR.
    Adequate capacitance but with high ESR is still a failed capacitor.
  • TennMan
    TennMan Posts: 1,262
    You are describing the symptoms of speakers that are out of phase. Check the polarity of the connections all the way from the amp to the speakers. It's possible the colors on the binding posts have been reversed. Do a battery test to make sure all the drivers in the speakers are moving in unison.
  • So I unplugged the cable that goes between the to speakers and now I have bass. It's not real tight bass but is full a and low. I think at this point I'm going to order the hardware to rebuild the crossovers. I have a question - I'm upgrading to the RD0198 tweeters in my SDA 2B's so can you do the same in the SDA SRS 2.3 speakers and if so what are the crossover changes that are need when doing this?
  • Gardenstater
    Gardenstater Posts: 4,136
    Interesting but have you checked that all the polarities are correct on the MW's AND done the push test correctly as per above ^^^ on both.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • The polarity seem to be correct on both speaker. When pushing the Passive Radiator in quickly and holing it there it takes the 6.5" drivers about 5 to 6 seconds to return to there mid position.
  • Gardenstater
    The dimensional speakers too? I would check the polarity of the interconnect cable and make sure it isn't wired incorrectly.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    edited October 2020
    Are these 2.3 or 2.3tl speakers?
    Pictures would help. 2.3 cannot be tl'd. Plus you would need all new drivers to go from 2.3 to 2.3tl. two very different beasts...
  • Schurkey
    edited October 2020
    While I grant that he'd need to change a heap of components in the HF section of the crossover, I don't see any reason the three-tweeter array couldn't be upgraded to '198s.
    If you're replacing the six tweeters anyway, and re-capping the crossover, it wouldn't be all that much more work to just build the crossovers as if they were 2.3TLs. Some extra caps, some extra resistors, a few inductors. Especially if he were to do it on Gimpod boards.
    Worst part would be potential level-matching between the "2.3TL" treble section and the "2.3" mid-bass section. Might have to play some games with resistors either in the treble or the bass.
    edited October 2020
    I guess I should have stated "easily" any hoots how is that 2.3tl crossover going to interact with all the different drivers 2.3 has?
    Your left speaker becomes the right the right becomes the left?
    At this point I guess with the outlaying of cash they're some dang fine other speakers out there for the kind of cash that is about to be plunked down.
    Yes the RD-0198 is a very good tweeter BUT there's not a dang thing wrong with the RD-194 either. The 198 is not the be all end all in tweeters lets be honest.
    F1nut Posts: 49,711
    tpeveler wrote: »
    NO!
  • TennMan
    tpeveler wrote: »
    That's just another sign that something is not right with the polarity of the speakers or crossover cable. I believe when you unplugged the crossover cable it allowed the dimensional drivers to work together with the stereo drivers resulting in more bass. @westmassguy would know more about this than I do but I believe what I'm saying is correct. You should solve this problem before replacing parts.
  • invalid
    TennMan wrote: »
    tpeveler wrote: »
    I'm not sure about the 2.3's, but I know my 2a's have less bass with the interconnect cable disconnected.
  • What is the pin out on the Crossover cable?
    Positive
    Blade goes to ground if I'm correct
  • Gardenstater
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
  • Checking between the ends of the cable I have continuity between the pins but the blades are open. Shouldn't there be continuity between the blades too?
  • Gardenstater
    Absolutely.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
  • So does that mean the cable is bad because I have two cables and they are both the same?
