New car audio build.
Had my "new" car for a little while now, and most of my parts have come in, so I've made some progress I stalling everything. Doing all new components front and rear, because I'm selling this car before I leave, and 4 working speakers is a better selling point than a good sounding 2 channel, and volume is a bit of the goal too, as 2 10s on 1950 rms is a lot of sub for 2 6.5s on 125 rms. Running alpine type gs in the doors, alpine type rs in a ported box, and an alpine ilx w650 for my head unit. Running nvx 16 awg silver tinned ofc speaker wires to the doors, to an NVX jad800.4 4 channel amp, and 8awg silver tinned ofc to the subs, from an NVX vad2700.1. the box isn't the greatest, the subs were bought with a box, and amp for about 2 bills on fb marketplace a coupe years ago. I rewired the box, 2ohm dvc subs, wired with the same 8awg, to a 2 ohm final impedance. Terminal cup sucked, but the hole is already there, so I put some bondo in to add some mass and stiffness, and cut out the spring terminals and replaced the with some copper cardas binding posts. Some wood glue and a couple deck screws fixed the rattley board in the port, and a bit of accoustic mat helps. Big 3 upgraded with 1 ought knu konceptz ofc for the power, and NVX silver tinned 1 ought for grounds. Should have enough of both to run to the trunk, so whichever one fits better will probably be what I run. Got the front speaks installed and big 3 done, with the head unit installed.
HT/2channel:
AVR: Yamaha RX-V 765
Fronts: Polk RTiA3
sub: Polk PSW110(will add 2x PSW 505)
Center: CS13
surrounds:Polk RTi4( also have some def tech pro Mon. 800s, may end up her or expanding this to 7 channel.)
TV: samsung 40
The real 2 Channel(work in progress):
Pre:HK 3490
Amp:Parasound 1200 MK II
Sub:RBH 1010-SEP
Speakers: Monitor 5A peerless
Headphones:
Source: FIIO X3 CD rips WMA lossless
Amp: FIIO E12, Nuforce icon udcac-2 W/pangea cable
Cans: Audio-Technica ATH-M50, Velodyne V-True, Grado SR225i
most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
"WITH WILLING HEARTS AND SKILLFUL HANDS,
THE DIFFICULT WE DO AT ONCE,
THE IMPOSSIBLE TAKES A BIT LONGER
WITH COMPASSION FOR OTHERS
WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"
Seabee Memorial, Arlington, VA
Fronts: Polk RTiA3
Center: CS13
TV: samsung 40
Pre:HK 3490
Sub:RBH 1010-SEP
Headphones:
Fronts: Polk RTiA3
Center: CS13
TV: samsung 40
Pre:HK 3490
Sub:RBH 1010-SEP
Headphones:
Fronts: Polk RTiA3
Center: CS13
TV: samsung 40
Pre:HK 3490
Sub:RBH 1010-SEP
Headphones:
Thanks man, it's a 2005 mk2 ford focus 5 door hatch. It's euro specs, and they got the second gen well before the US.
Fronts: Polk RTiA3
Center: CS13
TV: samsung 40
Pre:HK 3490
Sub:RBH 1010-SEP
Headphones:
The box will probably disappoint, I know almost nothing about it other than what ive done. But I'll do my best to get some pics. In my last car, I had it sounding fairly decent for not having any calibration tools.
Fronts: Polk RTiA3
Center: CS13
TV: samsung 40
Pre:HK 3490
Sub:RBH 1010-SEP
Headphones:
Fronts: Polk RTiA3
Center: CS13
TV: samsung 40
Pre:HK 3490
Sub:RBH 1010-SEP
Headphones:
Sorry for the mess, it's cleaned up now,
Fronts: Polk RTiA3
Center: CS13
TV: samsung 40
Pre:HK 3490
Sub:RBH 1010-SEP
Headphones:
Fronts: Polk RTiA3
Center: CS13
TV: samsung 40
Pre:HK 3490
Sub:RBH 1010-SEP
Headphones:
Not enough to blow the hair on my head around, but enough that my arm hair and the hair on the back of my neck will stand up.
Also have a gately audio flat pack box for a 15 coming, and if it fits, I'll have a 15 inch DDaudio redline 800 series in there. Although my trunk is till half way useable now, if I put that in there I lose the trunk entirely.
Fronts: Polk RTiA3
Center: CS13
TV: samsung 40
Pre:HK 3490
Sub:RBH 1010-SEP
Headphones:
Like WWE Monday night raw
Fronts: Polk RTiA3
Center: CS13
TV: samsung 40
Pre:HK 3490
Sub:RBH 1010-SEP
Headphones:
Here's the 10s in their box outside the car. Here's the 15 inch box sans sub. It's in the car now, sub bolted in with deck screws. Gonna paint the box with bedliner and mount the sub with threaded inserts. Got some more tuning and listening to do, but already, there's more bass, less punch, and a bit deeper sounding and feeling in the low end. I did dynamat the inside of the front baffle, and the wall directly behind the driver. Speaker gasket used. All I terminal wiring is silver tinned 8awg wire, and speaker cable is the same.
Fronts: Polk RTiA3
Center: CS13
TV: samsung 40
Pre:HK 3490
Sub:RBH 1010-SEP
Headphones:
Fronts: Polk RTiA3
Center: CS13
TV: samsung 40
Pre:HK 3490
Sub:RBH 1010-SEP
Headphones:
Fronts: Polk RTiA3
Center: CS13
TV: samsung 40
Pre:HK 3490
Sub:RBH 1010-SEP
Headphones:
Fronts: Polk RTiA3
Center: CS13
TV: samsung 40
Pre:HK 3490
Sub:RBH 1010-SEP
Headphones:
May try that, haven't checked with the engine revved up, and only notice it with cabin lights currently.
Fronts: Polk RTiA3
Center: CS13
TV: samsung 40
Pre:HK 3490
Sub:RBH 1010-SEP
Headphones:
Fronts: Polk RTiA3
Center: CS13
TV: samsung 40
Pre:HK 3490
Sub:RBH 1010-SEP
Headphones:
I’d definitely be looking for something bigger, at least 110/120 amp. HOWEVER, before you move up in amperage, make sure your cars ECU won’t try to do some weird voltage regulating. I’m not really familiar with the euro stuff, I think I read somewhere the euro versions may have voltage regulators built into the alternator. That could be a thing to check for also.
Call a Ford dealership and give them your VIN, they should be able to steer you in the right direction.
Car audio is fun, your work is pretty solid looking.
Question- Out of curiosity, did you mat the inside of the exterior door skins?
Thanks, I just stuck random small scraps in as far as I could reach, when I get me panel clips I may stick more inside since I'll have the panels off. I have an NVX 10 farad Cap I'm gonna try, won't solve the issues, but if I can get a good power buffer to keep it from dipping too bad, I should be ok. I do t crank it up full bass and full volume often or for long, and I have no issues at my normal listening levels. After having it loud for a while, it does seem muddied, like the power has gone away a bit. Were full quarantine here so going out to find an alt will have to wait a while.
Fronts: Polk RTiA3
Center: CS13
TV: samsung 40
Pre:HK 3490
Sub:RBH 1010-SEP
Headphones:
Fronts: Polk RTiA3
Center: CS13
TV: samsung 40
Pre:HK 3490
Sub:RBH 1010-SEP
Headphones:
