Digital Coax Cable
kevhed72
Signal Silver, AQ, Wireworld or other in 3 or 4 foot length....thanks!
I have a 2M Wireworld Starlight 7 if you are interested
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
A bit too long but thanks for checking!
Groovy. I'm rockin a new to me DAC2 and could use another. My glass optical cable is getting moved to TV duty upstairs.
Shoot me a PM on what you would want for the Wireworld....I need to measure when I get home later. 🙏I have a 3ft Monster digital coax and a .5m Wireworld Silver Starlight. Unfortunately, everything else is currently in use.
Not sure how quickly you need it but I have some MIT, Pangea, and Douglas Connection 1.5m digital coaxial cables that will be available in the next 3-6 weeks.
Also not sure if you need USB But I have a 1.5m Audioquest Forest USB if you need it. -
I’m interested in the USB of Kevin passes...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
I quite liked the AQ Forest USB. I also used the Forest RCAs with it. It was a pleasing combination for a headphone amp setup I was using.I disabled signatures.
But did it let you see the forest for the trees?
It did, and it was I was right there with Jane Wiedlin in Rush Hour.I disabled signatures.
Definitely interested in the MIT and Douglas cables....no need for a USB cable though. Thanks man!Not sure how quickly you need it but I have some MIT, Pangea, and Douglas Connection 1.5m digital coaxial cables that will be available in the next 3-6 weeks.
Sounds good. They're out on loan/demo right now but I'll follow up with you once I have them back in my possession.
@rooftop59 I can get the Forest USB shipped out to you next week. -
Pm sent!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Giesnote apogee wyde eye 75 ohm . You can get on Amazon for $40. Nice sounding cable.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Heard this cable at Marvin's house. Don't let the price and understated looks fool you, it's quality.Analog: Hana ML > VPI Prime Signature 21 > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
Discogs -
probably too late but I do have a Virtue Audio Digi Cable Tellurium Copper...Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
