Just got these RTA 12B’s.
They are going to need some work. They sound awful. The right one’s base sounds ok, but the tweeter is almost in audible. The left one sounds weak but the tweeter works well.
I'm guessing the crossovers will need rebuilt. What are the ohm specs for all the drivers?
John
«13456
    F1nut Posts: 51,789
    edited October 2020
    Test the fuse. If it tests ok then clean the fuse ends and the fuse holder clips. Check the mid-drivers for shifted magnets by gently and evenly pushing them in. If they don't move or you hear scratching the magnet has shifted.
    BTW, it's bass not base.
  • Gardenstater
    Gardenstater Posts: 4,783
    They should be DC resistance of 7.75Ohms if they are MW6501s. What tweeters do you have? Peerless tweeters are around 7.0 Ohm to 8.5 Ohms DCR depending upon the mfg date.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Bass! Ha! How could I?
    I’ll start checking tomorrow. Thanks for the reply.
    John
  • Nightfall
    Nightfall Posts: 10,084
    Those are well worth getting squared away.
    afterburnt wrote: »
    Village Idiot of Club Polk
    Tony M Posts: 11,625
    How did you get them? :p
  • Nightfall
    The bass made bass when he slapped the base of his tail against the surface of the water.
    afterburnt wrote: »
  • Tony M wrote: »
    They were on my local FB marketplace I talked them down a little (got em for 200, I should have gone lower) the only thing they had to “demo” them was a crappy old boom box.
    John
    Ok. One non functioning Peerless tweeter. The drivers feel smooth look and now sound to be working. They sure are power hungry. I’m currently driving them out in my garage (not permanently) with my old Onkyo Integra integrated amp. I’ll be running them in the house with a GFA 5503.
    Are the Sonicaps really 55 bucks each? 7 per speaker right?
    Yeesh!
    John
  • Gardenstater
    edited October 2020
    It's only $282 total per speaker not including shipping and sales tax :# That's if you use a 22 and a 33 Clarity Cap CSA (for the 55) and the rest Sonicaps.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    Strange. This is on the working tweeter. I don’t even know what it could have touched?
    John
    xschop Posts: 5,193
    Someone touched a soldering iron to it perhaps?
  • Gardenstater
    What are the #'s on each tweeter? Usually it is either 5514 or 7514 followed by a 4 digit date (Week and Year).
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    That’s the working one.
    Here’s the non working one.
    John
  • Gardenstater
    edited October 2020
    Pretty bad ink stamping job but I guess they are 41st week of 1981. What are the DC Resistances of the tweeters and the midbass drivers? Are the midbass MW6501's? You can read it off of the label on the back of the speaker (pole piece). Also, there should be a date somewhere on the crossovers, maybe on the one's inside the cabinet.
    There are lots of members that have these speakers and can advise you on crossover upgrading. @CH46E I know has these and has done them up fully.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    Inner. I had to push the insulation back up.
    John
  • Gardenstater
    edited October 2020
    Those drivers are dated 9/22/81 and the tweeters are 41st week in 81, so those pretty much jive with each other within several weeks anyways. I'm not sure when they came out with the RTA 12B. I think but have to verify that MW6600x and MW6501 may be close to each other in parameters.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    edited October 2020
    No date on the inner XO then. Anyway, I think they put the MW660X's in before they made a switch to MW6501 at some point in time......maybe late 84. The MW6600X seems to be a mystery to everyone as far as what Small Thiele Parameters it is supposed to have.
    You need to check and verify that your XO's match the schematic in the archives for the RTA 12B. Probably they do.
    You should also still check all the DC resistances of every driver and make sure they are close to each other. That bad tweeter will probably be 0 Ohms if it is a fried voice coil.
    This thread is about one that had a XO serial number close but a little earlier than yours:
    https://forum.polkaudio.com/discussion/191073/help-identifying-rta-12-12b-12c/p1
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • CH46E
    CH46E Posts: 3,595
    Thanks for the vote of confidence George. Since my cabinets are not in the best shape and I now have 2 other projects going on, i might be parting mine out. Can't believe I just said that.
    Of course members here would have 1st crack at discounted prices for anything a let go.
  • Harv2002
    Harv2002 Posts: 56
    edited October 2020
    I’ll check the other drivers tonight. However I haven’t disconnected any drivers yet as you guys know they are soldered.
    John
  • CH46E
    CH46E Posts: 3,595
    None of mine were soldered. Thats odd. They must have ran out of spades?
  • Nightfall
    Do I need to start saving up for your speakers minus the cabinets @CH46E ? Are they Bs with Peerless and 6600Xs?
    afterburnt wrote: »
  • Gardenstater
    edited October 2020
    "That bad tweeter will probably be 0 Ohms if it is a fried voice coil.
    Doh! I meant to say open circuit or infinite Ohms.
    My 79 vintage 7B's were all soldered.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Harv2002
    Harv2002 Posts: 56
    edited October 2020
    All my drivers are MW6600X
    The schematic I downloaded shows MW6501 drivers. Am I to understand the crossovers are not different?
    John
  • CH46E
    CH46E Posts: 3,595
    edited October 2020
    Pretty sure the crossovers are identical. I believe mine has one 6600x and one 6501 in each cabinet. I think the 6600x was used as a drop in for the 6501.
    You should be good with 4 6600x.
    Just know the speakers are marked for left channel and right channel. L AND. R should precede the serial number. Also make sure the plugs behind the tweeters and croosover are in thier correct position. Mine came jammed into the wrong orientation and that will fry a tweeter in a heart beat.
    pitdogg2 Posts: 27,064
    MW6600 came first. The drivers I've always thought were the same or so close it didn't matter. My SDA 1 signature speakers came with all mw6600 with mw6501 in the dimensional spots. From what I've see the speakers that used both except for tweeter differences the XO is the same for the drivers between mw6600 and mw6501.
  • Anyone have a nice used Peerless tweeter?
    I’d like to avoid buying two new repo’s.
    Or do I go RD0194’s like I did with my Monitor 10’s?
    John
  • CH46E
    CH46E Posts: 3,595
    Rdo194s are not a sutible replacement forbthe peerless. Let me put some of mine on a meter tomorrow. I think inhave 3 good ones. But let me double check. If I do have a 3rd you can have it for the cost of shipping.
  • CH46E wrote: »
    Thanks so much for the offer. Let me know.
    Was I thinking RD098? I still don’t have all these tweeters straight in my head.
    John
