SDA SRS 2.3tl
Although in my current situation I wouldn't mind more good tight lower end. My room just sucks out the bass.
So are you connected to high pass or full range in back? Have you tried bypass? If all else turn up the bass to the desired output.Gustard X26 Pro DAC
I am using the main full range output. I have tried the bypass button but I have it adjusted flat +/- 0 on both treble and bass so it doesn't make any discernible difference. I will knock out the crossover refresh over the next few months and see how things stand after that.SDA SRS 2.3tl, SDA 1C, SDA 2B (TL mod), Reserve 200
nooshinjohn wrote: »Don't upgrade your cables just yet. I agree they could help, but nowhere near what you will get by stepping up your amp/preamp/source first.
John is 100% correct. Put the $ into mods and a top notch Pre and amp. He recommended I get the Pass Labs X1 and I have never regretted that purchase. Enjoy the new speakers!____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
Congratulations on your 2.3 tls enjoy them. I own a pair and have had them hooked up to two different Adcom amps and a Parasound amp with a Vincent preamp and I'm very happy with them. Once again enjoy them.Home Theater
Why is it your old gear list looks like my old setup?
nooshinjohn wrote: »nooshinjohn wrote: »Don't upgrade your cables just yet. I agree they could help, but nowhere near what you will get by stepping up your amp/preamp/source first.
Well it sure doesnt look like your current gear list! Theres one reason for that, $$$$
Time to start upgrading these 2.3s.
Purchased the following:
GIMPOD Boards
Sonicap gen I to replace all caps
2 Gen I Sonicap 5.8 uF 200VDC
2 Gen I Sonicap 8 uF 200VDC
2 Gen I Sonicap 16 uF 200VDC
2 Gen I Sonicap 18 uF 200VDC
2 Gen I Sonicap 27 uF 200VDC
2 0.50 Ohm Vishay Mills MRA-12
4 22.5 Ohm Vishay Mills MRA-12
New connectors from Mouser
Sonic Barrier 3/4" 3-Layer Acoustic Sound Damping Material
#8-32 Hurricane Nuts
Black-Oxide Alloy Steel Socket Head Screw 8-32 Thread Size, 7/8" Long
Dynamat
I did opt for the precision matching from Sonic Craft. I have some hardware left over from the 2Bs that I did last year so I didn't need the full compliment of Hnuts or screws as I already have some on hand.
I hope to get most of the soldering done next weekend. I may knock out some of the hardware install once things arrive over the next week.
I opted to wait on the tweeters, for now. I really find the SL3000 tweeters to sound pretty good. No doubt I will end up upgrading to the RD0198 at some point, but I figure this way I will get to experience and appreciate the improvement they provide independently form the XO refresh.
SDA SRS 2.3tl, SDA 1C, SDA 2B (TL mod), Reserve 200 -
Same path I took. I really liked the SL3000 tweeters myself but let me tell you, if you are like me you'll want kick yourself for waiting so longI opted to wait on the tweeters, for now. I really find the SL3000 tweeters to sound pretty good. No doubt I will end up upgrading to the RD0198 at some point, but I figure this way I will get to experience and appreciate the improvement they provide independently form the XO refresh.
Especially since Polk is no longer stocking them and has given them to Midwest Speaker Repair. No telling how long it will be now before there are no more... My advice is to get them now or cry about it later.
https://www.midwestspeakerrepair.com/shop/home-audio/tweeters/polk-audio-1-tweeters/polk-audio-sl2500-sl3000-1-inch-dome-tweeter/The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I'd go with the 1 1/4" Sonic Barrier CalvinHome Theater/2 Channel:
dhsspeakerservice.com/ -
You are probably right. I should order them now even if I don't plan to put them in immediately. Better safe than sorry.nooshinjohn wrote: »Polk is no longer stocking them and has given them to Midwest Speaker Repair. No telling how long it will be now before there are no more... My advice is to get them now or cry about it later.
What do you think the difference would be (other than 1/2" of thickness)? The 3/8" stuff already shipped so it is on the way. I'm sure I will be able to use it for other projects in the future if I do order the thicker stuff.westmassguy wrote: »I'd go with the 1 1/4" Sonic Barrier
Marines are ALWAYS right!
Marines are always extra special, thats for sure....JK , love my Marine brothers and sisters out there.nooshinjohn wrote: »Marines are ALWAYS right!
The last of the piece parts arrived yesterday so I got started last night. I removed the drivers, installed the Hnuts and applied dynamat before I went to bed last night. Short day at for today so I got right back at it. Just finished the first (left side) and I decided to hook them up to see if I can hear a difference.
Looks great Caleb!
You're in for a treat!
Finished up a few hours ago. I look forward to hearing the improvements over then next weeks.SDA SRS 2.3tl, SDA 1C, SDA 2B (TL mod), Reserve 200
Nicely done! Now if someone can convince you into a good tube pre...Gustard X26 Pro DAC
Just wait until you install the RD0’s
I'm sure it would be a huge jump forward for stereo sound. Next up will either be this or building a dreadnaught.
A few things are stopping me from picking up a pre:
1. I really enjoy HEOS to stream Amazon HD and with the CD player/streamer in the other system I am committed at this point.
2. The living room system is currently 3 channel (center with no rear). I was not happy with a pure stereo for watching TV.
3. Cost. I would be replacing the HT and pre (with bypass).
It just seems to me that unless I am willing to put at least 2K toward this upgrade I may not see any improvement.
Curious to know what you think?SDA SRS 2.3tl, SDA 1C, SDA 2B (TL mod), Reserve 200 -
Get the RD0-198’s. They sound noticeably better and and image a little better as well. Another upgrade to consider is a beefier inductor for the bass. Following Darqueknight’s lead I installed the Solen 10 awg - cleaner, clearer bass with more slam."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
The 198's are definitely part of the plan. I also pulled the Erse Super Q inductors from my 1C and installed them a few weeks ago. I had those sent to @westmassguy to be properly modified. I don't feel like I am suffering from a lack of bass at all. Even with the SVS turned off there is plenty of low end.drumminman wrote: »Get the RD0-198’s. They sound noticeably better and and image a little better as well. Another upgrade to consider is a beefier inductor for the bass. Following Darqueknight’s lead I installed the Solen 10 awg - cleaner, clearer bass with more slam.
I would be interested in the difference the Solen may make. Do you have a link to oint me in the right direction?
For some reason I keep forgetting to mention I also added spikes a week or so ago. I picked up a set of 8 footers (spiked version) from Tekton Designs. 20 bucks plus shipping. They are a simple design, but seem to work just fine.
https://tektondesign.com/footers.html
I am not sure that the sliders that my 2.3's came with are the what was originally provided by Polk, but now that they are in place for good I wanted to add spikes.SDA SRS 2.3tl, SDA 1C, SDA 2B (TL mod), Reserve 200 -
https://solen.ca/products/inductors/standard-inductors-10awg-2-59mm/s1016-0/
https://forum.polkaudio.com/discussion/123728/review-of-new-solen-inductors-in-2-3tls➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
