Peachtree Nova Amps & SDA 1s
Anyone using, or used, Peachtree Nova amps with SDA 1s?
Specifically Nova 150 or 300. I have SDA 1c speakers with updated xovers and new tweeters (along with upgrades to enclosures).
If there is an existing relevant post I was unable to find on app version of forum.
Paul
  • Schurkey
    Schurkey Posts: 2,122
    If they're common-ground, I'd expect them to be fine. A 6-ohm nominal load shoudn't be a challenge for a competently-designed amp.
    The problem is that there are so many INcompetently designed amps sold under both new and established brand names.
  • Aren't those class D? Not common ground?
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
  • engie490
    engie490 Posts: 438
    I am using an NAD M22 v2 with my SDA-1Cs with updated tweeters. Definitely class D and common ground. Sounds great!
    The Peachtree NOVA 300 was measured in Stereophile so you can see how competent it is.
    Hales System Two Signatures / Bryston 7B STs / McCormack RLD-1 / Innersound Phono / Bluesound Node 130 /Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
  • I auditioned in store (NOT SDAs (GE 5s)), was pleased...seemed more musical than my previous. Replacing a NAD C390DD (class D, common ground) that is now best suited for use as a small boat anchor.
    Thanks for the feedback (and I think I've read every available review of the Nova 150/300s). Just a bit leary of the more complex amps after writing off a fairly pricey amp, so all the built ins are a bit of a deterrent. Going to audition it and a PrimaLuna, with much less WPC.
    Paul
    F1nut Posts: 51,676
    I was involved in a conversation with another about this. From Peachtree, "All of the Nova power amplifer sections are fully-differential designs", which should mean they are not common ground.
  • Thanks...I will have to double check...makes the selection narrower.
  • engie490
    engie490 Posts: 438
    You may want to look up Peachtree’s customer service and QC. Both have been questioned in other audio forums.
  • Thx. Submitted question yesterday, will post response when received.
  • From Peachtree:
    Hi Paul,
    Thanks for writing in. Since our amp is internally bridged, they do not have a common ground.
    I hope this helps, please let me know if you have any other questions.
    Sincerely,
    Service Coordinator
    Peachtree Audio
    pitdogg2 Posts: 26,931
    There you have it!
