L600 “height input only”
I just purchased a pair of L600. On the back there are 6 total binding posts. I understand that the 4 grouped together are for bi-wiring or bi-amping. But the top 2 have a sign that says: “height input only.” What does that mean? There is nothing in the owner’s guide to explain it.
  • vmaxervmaxer Posts: 4,900
    You can add height speakers to the top of those.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • pitdogg2pitdogg2 Posts: 18,288
    edited September 2020
    For atmos surround sound. Instead of hanging speakers on the wall/ceiling they are on top of the 600's. Many speaker manufacturers use the same principal.
  • EmlynEmlyn Posts: 2,882
    The height modules are called L900 and are an extra cost option for the L600 and L800 floor stander speakers...
    https://www.crutchfield.com/S-kmtPZUMKXMJ/p_107L900B/Polk-Audio-Legend-L900.html
    1. Polk LSiM-707, LSiM-704C, LSiM-702FX; Dual SVS SB2000 subwoofers; Marantz SR7011 receiver; Parasound A31 and A23 amps; Oppo 205; Sony 65" 4K TV; FIOS; PS Audio Power Plant Premier; MIT S2 cables
    2. JM Labs Electra 920.1; Parasound JC2 and JC5; Sony HAP-Z1ES; Marantz SA8004 SACD; Music Hall MMF7 and Acoustech phono pre; PS Audio P1000; MIT S1 Cables
    3. Polk LSiM703; Anthem Pre-2L SE; Parasound A21; Sony 48" 4K TV; Wyred4Sound DAC 2; Oppo 203; Squeezebox Touch; PS Audio Power Director 4.7; MIT S3 cables
  • That makes sense. So if I’m not going to bi-wire or bi-amp, which of the 4 should I connect to?
    All four lower binding posts are used for biwire or biamp. Remove the straps connecting the pairs of binding posts if using both lower sets.
    The set with the strap connection
Howdy, Stranger!
