Vintage Monitor and SDA Speaker Deals
1199200202204205257
    Tony M Posts: 11,615
    10 hours to go...Santa Barbara Cal. . 52.00 but reserve has not been met. :|
    https://www.ebay.com/itm/184451125023?ul_noapp=true
  • Tony M wrote: »
    How much is the reserve?
  • Gardenstater
    Gardenstater Posts: 4,779
    edited September 2020
    Can an eBay seller remove the Reserve Requirement during the bidding if they wish?
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • xsmi
    xsmi Posts: 1,801
    krazypolk wrote: »
    Tony M wrote: »
    2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
    krazypolk wrote: »
    Tony M wrote: »
    You have to contact the seller to find out.
    Or if the bidding goes high enough, it will show reserve has been met. The bidding can continue on though if a bidding war happens.
    pitdogg2 Posts: 27,029
    You used to be able to.
  • 17 minutes left and the bidding is still at 52 dollars.
  • vmaxer
    vmaxer Posts: 5,120
    They have been relisted.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • I'm not surprised that he didn't get much interest. He's got ZERO feedback and his first auction is for 30-year-old, very large speakers with local pickup only. Just put a BIN price on there and let it ride.
    Infinity RS-1Bs / Bryston 7B STs / Sonic Frontiers Power 2 / Jeff Rowland Consonance / Bluesound Node 130 /Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
    I actually forgot to look at the sellers sales/purchase record. :s
    Yea, 0 doesn't help one bit.
    Now this is a smokin deal.
    RD-0?s already in place.
    1250.00
    Santa-Monica Ca.
    These look great! Tape or light suction can fix those dust caps.
    https://www.ebay.com/itm/114432753359?ul_noapp=true
  • So which model might these be?
  • His ad says SRS and there are 13 screws on the crossover plate, so without a picture of the serial number and/or terminal cup, we have to believe him.
    Hopefully, those tweeters are 194s and all of the mids are correct. He states in the ad that all of the drivers were replaced 8 years ago.
    audioluvr Posts: 5,905
    They are SRS's the drivers say Polk on them so he probably means he replaced the tweeters
  • My bad...there is one pic of a serial number. Using the magnifying tool in ebay, it looks like 5226 or 5228. So, assuming the other channel is around the same number, they should work with the Dreadnaught or AI-1. If the left channel is less than 5000, then not so much...
  • The type of interconnect socket is the determining factor of what they are.
    Blade/blade = Original SDA SRS (non-compatible with Dreadnaught or AI-1).
    Pin/Blade = SDS SRS 1.2 The speakers either have the RD0-194's or they been TL'd depending if the RD0-198 tweeters are installed along with the appropriate changes to the crossover) or they are SDA SRS 1.2TL with the RD0-198's. Dreadnaught or AI-1 compatible.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Gardenstater
    edited October 2020
    These early 5's with silver basket MW's and Peerless look pretty nice but typical NJ market prices $180
    https://www.ebay.com/itm/PAIR-Vintage-Polk-Audio-Monitor-5-Speakers-with-Peerless-Tweeters-Early-version-/133457735176?_trksid=p2385738.m4383.l4275.c10
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • https://www.ebay.com/itm/303715170405
    Not really a deal, but they look like they're in great shape.
  • jdjohn
    jdjohn Posts: 3,343
    A pair of SDA-SRS in Nashville for $1,000...but missing a mid. They look to be in good condition otherwise.
    https://nashville.craigslist.org/ele/d/nashville-vintage-polk-audio-floor/7209400086.html
  • vmaxer
    vmaxer Posts: 5,120
    I just got home from Nashville a couple hours ago.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • michaeljhsda2
    michaeljhsda2 Posts: 2,200
    edited October 2020
    Those are 1.2's which can be converted to 1.2tl's. The binding post nuts need to be reversed, in order to hear them in correct phase. The diagram on the back is for the original SRS (blade/blade IC socket) and these are pin/blade.
    SDA SRS 2.3TL's
    SDA 2B TL's
    Looks like that one driver was torn out as you can see the spider.
  • jdjohn
    jdjohn Posts: 3,343
    Yeah, wondering if these are worth the price given the need for a replacement mid, crossover upgrades, etc.
  • engie490
    engie490 Posts: 439
    I'd buy 'em! Can someone pick 'em up for me and deliver to Colorado? I'll definitely buy you some brews from some of the local breweries...
  • jdjohn
    jdjohn Posts: 3,343
    I could probably get his price down a bit because of the damaged woofer. Of course I'd want to check movement on the other mid-woofers, and check overall condition. Hmmm...
  • JayCee
    JayCee Posts: 1,508
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • engie490
    engie490 Posts: 439
    jdjohn wrote: »
    Nice Work! It's down to $800!!!!!!!
  • Gardenstater
    How does a woofer cone get ripped off of the spider and surround?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
