Now I have all the important stuff in my shed/shop
  • afterburnt
    afterburnt Posts: 7,892
    edited September 2020
    afterburnt wrote: »
    @mhardy6647 are you running "mini splits" ? If so which ones?
    Yeppers. Mitsubishi High-Efficency (H2I). We now have two outside units (three inside) now, mostly for A/C but also for milder weather heat and as a backup in case anything bad happens to the boiler (or if we run outta propane). Electricity comes from the sun (mostly), so they're basically cost-free to run, and quiet, too.
    Here's a not particularly good photo of the current install (don't mind the weeds).
    I told Mrs. H that our house has become the energy equivalent of a mullet. Business in the front, party in the back.
    SWEET! I love your house, very Colonial, is it vintage? I'm getting the Mitsubishi A6M hyper heats installed next week ( I hope ) The raunchy cats should love it. I am just gonna live in the shed, it's cozy and got to cost me ten grand by now.
    Is your solar an "off the grid" set up?
    nooshinjohn Posts: 25,933
    Do you have a runway at your place? This is the only Mitsubishi A6M I know of.
    mhardy6647 Posts: 35,060
    afterburnt wrote: »
    afterburnt wrote: »
    Not off the grid (well... not yet, anyway) -- it's a net metering setup. About (nominally) 6 kW worth of panels on the roof and solar pre-heat for the domestic hot water up there, too.
    Party on! :)
  • invalid
    invalid Posts: 1,469
    A pure-play heat pump does its heat exchanging with a compressible gas (some sort of chlorofluorcarbon -- the ozone-friendly, modern cousin of old-school Freon) and doesn't require humidity. It's basically an air conditioner that can run in either direction, as required, to bring the air temperature to a desired set point.
    Ours will work with modest efficiency (60 percent) down to something like -20 degrees F. I am a big fan (no pun intended... well... not really, anyway).
    Heat pumps are pretty neat, I wish they worked at lower temperature, being I live in Michigan I would need electric heat alongside the heat pump.
  • fish357
    fish357 Posts: 304
    invalid wrote: »
    Heat pumps are equipped with electric coils that heat up to aid in ambient heat transference.
  • afterburnt
    @invalid Hyper Heats are supposed to work down to -13
    afterburnt wrote: »
    That is correct (actually even a bit lower, if memory serves), and I can vouch for them empirically :) -- they do NOT have auxillary electric (resistive) heat! If you live someplace really cold, you do need backup. We get below -10 or so just a few nights a year (and we have whole house hot water heat of various kinds).
  • invalid
    afterburnt wrote: »
    I need one of these for my audio room. I been using an electric heater in the winter and a window air conditioner in the summer. I leave my audio gear on all the time, so it heats the room in the fall and spring pretty well.
    invalid wrote: »
    afterburnt wrote: »
    That's a big 10-4.
  • afterburnt
    invalid wrote: »
    afterburnt wrote: »
    I just realized I could have saved the money on the 5th mini split by leaving my hot **** Emo monoblocks on all winter and installing the window ac unit that's sitting on the floor for summer.
  • Upstatemax
    Upstatemax Posts: 2,748
    Spending a bit of time in the bike cave today. Building my Salsa Timberjack back up for more of a “townie bike”.
    AKA, bike I can drunkenly ride around on...
    I’ll save my better bikes for when I’m sober.
