LSi15 both tweeters not working.
So I pulled out both tweeters and they are at 4ohms , safe to say they are not the problem.
I pulled out the crossover and looked for the 2ohm resistor that always burns out, but everything looks fine to me... Am I missing something? sm3bv2dwh0jm.jpg
Best Answers
    F1nut Posts: 51,938
    edited September 2020 Answer ✓
    Unless you want to upgrade the resistors you can just replace the damaged one with like for like.
    F1nut Posts: 51,938
    Answer ✓
    That 2 ohm/5 watt resistor should have been a 10 watt, so a 12 watt would be fine. Replace all with Mills for better sound performance.
    F1nut Posts: 51,938
    Answer ✓
    I'm glad to hear your speakers are working again. Hopefully, you upgraded all the resistors while you were in there.
Answers
