SDA SRS 2.3tl
13»
    pitdogg2 Posts: 27,339
    Although in my current situation I wouldn't mind more good tight lower end. My room just sucks out the bass.
    audioluvr Posts: 5,990
    So are you connected to high pass or full range in back? Have you tried bypass? If all else turn up the bass to the desired output.
  • Navy_Goat
    Navy_Goat Posts: 375
    I am using the main full range output. I have tried the bypass button but I have it adjusted flat +/- 0 on both treble and bass so it doesn't make any discernible difference. I will knock out the crossover refresh over the next few months and see how things stand after that.
    SDA SRS 2.3tl, SDA 1C, SDA 2B (TL mod), Reserve 200
  • dpowell
    dpowell Posts: 3,081
    Don't upgrade your cables just yet. I agree they could help, but nowhere near what you will get by stepping up your amp/preamp/source first.
    John is 100% correct. Put the $ into mods and a top notch Pre and amp. He recommended I get the Pass Labs X1 and I have never regretted that purchase. Enjoy the new speakers!
    gudnoyez Posts: 8,174
    Congratulations on your 2.3 tls enjoy them. I own a pair and have had them hooked up to two different Adcom amps and a Parasound amp with a Vincent preamp and I'm very happy with them. Once again enjoy them.
    nooshinjohn Posts: 26,002
    dpowell wrote: »
    Why is it your old gear list looks like my old setup? o:):p
  • dpowell
    dpowell wrote: »
    Well it sure doesnt look like your current gear list! Theres one reason for that, $$$$ :wink:
  • Navy_Goat
    Time to start upgrading these 2.3s.
    Purchased the following:
    GIMPOD Boards
    Sonicap gen I to replace all caps
    2 Gen I Sonicap 5.8 uF 200VDC
    2 Gen I Sonicap 8 uF 200VDC
    2 Gen I Sonicap 16 uF 200VDC
    2 Gen I Sonicap 18 uF 200VDC
    2 Gen I Sonicap 27 uF 200VDC
    2 0.50 Ohm Vishay Mills MRA-12
    4 22.5 Ohm Vishay Mills MRA-12
    New connectors from Mouser
    Sonic Barrier 3/4" 3-Layer Acoustic Sound Damping Material
    #8-32 Hurricane Nuts
    Black-Oxide Alloy Steel Socket Head Screw 8-32 Thread Size, 7/8" Long
    Dynamat
    I did opt for the precision matching from Sonic Craft. I have some hardware left over from the 2Bs that I did last year so I didn't need the full compliment of Hnuts or screws as I already have some on hand.
    I hope to get most of the soldering done next weekend. I may knock out some of the hardware install once things arrive over the next week.
    I opted to wait on the tweeters, for now. I really find the SL3000 tweeters to sound pretty good. No doubt I will end up upgrading to the RD0198 at some point, but I figure this way I will get to experience and appreciate the improvement they provide independently form the XO refresh.
    edited October 2020
    Same path I took. I really liked the SL3000 tweeters myself but let me tell you, if you are like me you'll want kick yourself for waiting so long
    Especially since Polk is no longer stocking them and has given them to Midwest Speaker Repair. No telling how long it will be now before there are no more... My advice is to get them now or cry about it later.
    https://www.midwestspeakerrepair.com/shop/home-audio/tweeters/polk-audio-1-tweeters/polk-audio-sl2500-sl3000-1-inch-dome-tweeter/
  • westmassguy
    westmassguy Posts: 6,850
    I'd go with the 1 1/4" Sonic Barrier Calvin
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Navy_Goat
    You are probably right. I should order them now even if I don't plan to put them in immediately. Better safe than sorry.
    What do you think the difference would be (other than 1/2" of thickness)? The 3/8" stuff already shipped so it is on the way. I'm sure I will be able to use it for other projects in the future if I do order the thicker stuff.
    edited October 2020
    Navy_Goat wrote: »
    Marines are ALWAYS right! :p:p:p
  • Navy_Goat
    Marines are always extra special, thats for sure....JK , love my Marine brothers and sisters out there.
  • Navy_Goat
    The last of the piece parts arrived yesterday so I got started last night. I removed the drivers, installed the Hnuts and applied dynamat before I went to bed last night. Short day at for today so I got right back at it. Just finished the first (left side) and I decided to hook them up to see if I can hear a difference.
  • westmassguy
    Looks great Caleb!
    Viking64 Posts: 7,629
    You're in for a treat! :)
  • Navy_Goat
    Finished up a few hours ago. I look forward to hearing the improvements over then next weeks.
    Nicely done! Now if someone can convince you into a good tube pre...
    Navy_Goat wrote: »
    Just wait until you install the RD0’s
  • Navy_Goat
    edited October 2020
    audioluvr wrote: »
    I'm sure it would be a huge jump forward for stereo sound. Next up will either be this or building a dreadnaught.
    A few things are stopping me from picking up a pre:
    1. I really enjoy HEOS to stream Amazon HD and with the CD player/streamer in the other system I am committed at this point.
    2. The living room system is currently 3 channel (center with no rear). I was not happy with a pure stereo for watching TV.
    3. Cost. I would be replacing the HT and pre (with bypass).
    It just seems to me that unless I am willing to put at least 2K toward this upgrade I may not see any improvement.
    Curious to know what you think?
  • drumminman
    drumminman Posts: 3,396
    Get the RD0-198’s. They sound noticeably better and and image a little better as well. Another upgrade to consider is a beefier inductor for the bass. Following Darqueknight’s lead I installed the Solen 10 awg - cleaner, clearer bass with more slam.
  • Navy_Goat
    drumminman wrote: »
    The 198's are definitely part of the plan. I also pulled the Erse Super Q inductors from my 1C and installed them a few weeks ago. I had those sent to @westmassguy to be properly modified. I don't feel like I am suffering from a lack of bass at all. Even with the SVS turned off there is plenty of low end.
    I would be interested in the difference the Solen may make. Do you have a link to oint me in the right direction?
  • Navy_Goat
    edited October 2020
    For some reason I keep forgetting to mention I also added spikes a week or so ago. I picked up a set of 8 footers (spiked version) from Tekton Designs. 20 bucks plus shipping. They are a simple design, but seem to work just fine.
    https://tektondesign.com/footers.html
    I am not sure that the sliders that my 2.3's came with are the what was originally provided by Polk, but now that they are in place for good I wanted to add spikes.
  • JayCee
    JayCee Posts: 1,509
    Navy_Goat wrote: »
    https://solen.ca/products/inductors/standard-inductors-10awg-2-59mm/s1016-0/
    https://forum.polkaudio.com/discussion/123728/review-of-new-solen-inductors-in-2-3tls
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
